Fuel Metering
Old Oct 13, 2001 | 01:06 AM
ccoffin's Avatar
ccoffin
Fuel Metering
How do you adjust the fuel metering screw accurately on an injection pump? The pump and injectors are new, but mileage had not increased, remaining at 15 or so. I am wondering if I can do this myself or if it requires a Ford specialty tool set. The manual only shows a cutaway view of the pump with the screw labled, but offers no advice on setting it. I have heard that this adjustment can affect power vs economy, and I am curious if anyone has any experience with it. Thanks.
Old Oct 13, 2001 | 04:18 AM
The Diesel Dude's Avatar
The Diesel Dude
Fuel Metering
If your question is how to adjust the fuel metering screw "accurately", it is done on a Stanadyne flow test bench. If you want your mileage to go up you'll have to reduce the fuel rate which will also reduce your available power. If you adjust the fuel rate to give you more power you'll likely get a corresponding reduction in mileage.
Old Oct 13, 2001 | 02:59 PM
ccoffin's Avatar
ccoffin
Fuel Metering
Thanks for responding. Do Ford dealers have this bench or do I need to find a diesel shop to do it? I assume that the pump has to be removed to adjust it.
Old Oct 17, 2001 | 08:28 PM
fordiesel69's Avatar
fordiesel69
Fuel Metering
If you really want to give up some power for fuel economy, then you need to remove a small plate with two screws on the passenger side of the pump. Line up the mark on the crankshaft with the line on the indicator. There should be a 5/32 or so allen screw inside. If it is not there, then turn the engine one more complete turn, the pump turns 1/2 crankshaft speed. Once you find the screw, turn it counterclockwise to reduce the amount of fuel and turn it clockwise to increase the amount of fuel. Just the opposite of a carb. Only try one or two flats on the allen wrech at a time and test drive it. A little goes along way.
You don't need any fancy equipment if you can remember how much you turn it incase you want to put it back.
1986 F-250 6.9 diesel,4x4,XLT Lariat,Ex Cab, 8'bed,etc...
Old Oct 17, 2001 | 08:31 PM
fordiesel69
Fuel Metering
If you need step by step instructions or want more info, just drop a line at: compman55(No Email Addresses In Posts!)
Old Oct 21, 2001 | 07:04 PM
ccoffin's Avatar
ccoffin
Fuel Metering
Thank you for your help, I am heading out to try to adjust it. Maybe by running Stanadyne in it I can make up for the power loss, if not a Banks Stinger System is going on my Christmas list. Santa, don't fail me now... I will e-mail if I have trouble.
Old Oct 22, 2001 | 11:43 AM
JoelSteven's Avatar
JoelSteven
Fuel Metering
shark13
Jan 23, 2011 07:50 PM
c00nhunterjoe
27
Dec 16, 2009 06:55 AM
jwxb41b
Jun 20, 2006 08:56 PM
