instrument cluster moisture
Old May 20, 2004 | 11:44 PM
handx2's Avatar
handx2
i`ve noticed lately that when i drive in the rain ,or when i run through a mudhole.my instrument cluster gets tiny little droplets inside the lens.i can`t find moisture anywhere else in the truck,where could it be coming from?
Old May 21, 2004 | 06:35 AM
FordBoypete's Avatar
FordBoypete
A damaged speedometer cable casing.
It may well be related to problems you have above with your transmission also.
Transmissions that have been submerged enough to get water in them vent through a case vent, unless it gets clogged/ stopped up, then they vent thru speedo cable & inputshaft housing where throwout bearing rides.
Additionally water in tranny gear oil kills thrustwashers, roller needles and sometimes syncro shoes in 2nd-3rd synchronizer, especially if it sits or sat with water in it.
FBp
ponyman_65
Oct 2, 2014 08:07 AM
genevanvoorst
Aug 26, 2014 05:56 AM
sammy77
Mar 11, 2012 08:50 AM
hush210
1997 - 2003 F150
Feb 23, 2007 08:37 PM
