Instrument cluster
Old Feb 28, 2012 | 07:00 AM
sammy77's Avatar
sammy77
Instrument cluster
Anyone know what size bulbs are in instrument clusters? 194's?? I've got a couple out on the left side and I'm just gonna replace them all when I remove it. Thanks
Old Feb 28, 2012 | 10:46 AM
tonefordays's Avatar
tonefordays
I replaced a few bulbs in my '06 6.0 PSD cluster a few months ago, this is what I used. 14.0v -1.4w Sylvania 74LL, 2pack for $4 @ autozone.
Old Feb 28, 2012 | 09:55 PM
firedaniel's Avatar
firedaniel
Amazon.com: Eiko 40648 - 37 Miniature Automotive Light Bulb: Home Improvement
Just did mine...
Old Feb 29, 2012 | 05:48 AM
sammy77's Avatar
sammy77
Thank you. How many were there?
Old Feb 29, 2012 | 05:56 AM
zhilton's Avatar
zhilton
I've been putting allot of thought into converting mine to LED once they start to burn out.
SloanLED - 513-147 - Optoelectronics & Lighting - Lamps - Allied Electronics
Old Feb 29, 2012 | 06:48 AM
fordguy61mi's Avatar
fordguy61mi
How do you replace the bulbs? Do you have to remove the dashboard? Is there a post that tells how to do it? I have a couple bulbs out in my cluster as well.
Old Feb 29, 2012 | 07:43 AM
tonefordays
Take a look here.
https://www.ford-trucks.com/forums/1...l#post10968491
Hope this helps.
Old Feb 29, 2012 | 07:54 AM
fordguy61mi
Originally Posted by tonefordays
Thank you!
Old Mar 1, 2012 | 05:45 AM
sammy77's Avatar
sammy77
I have thought about this as well, anyone ever try them?
Old Mar 1, 2012 | 10:30 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
dont get those kinda LED bilbs to put in ur instrument panel.if u do u will have dark spots in it. i tried a few a friend had left over from putting them in his 98 Z71. i found these on ebay an they should b here next week. i will report back if they work good or not.
Old Mar 1, 2012 | 11:09 AM
sammy77's Avatar
sammy77
Please let us know, thanks.
Old Mar 1, 2012 | 02:09 PM
Scott6.0PSD's Avatar
Scott6.0PSD
Your right. I used the 74-GHP from superbrightleds.com. Two of the bulbs for the speedometer create bright spots. Its not too bad, but I may eventually change them back.
Old Mar 1, 2012 | 02:18 PM
zhilton's Avatar
zhilton
That didn't dawn on me right away, I'm just wanting to reduce the electrical load on my truck. Same reason I'm trying to find the right fixtures for my trailer. +2 on the keep us posted on how those work out for you.
Old Mar 2, 2012 | 04:11 AM
fordguy61mi
How many bulbs are there in the cluster? I might as well change them all while I'm in there to replace the burned out one.
Old Mar 11, 2012 | 08:20 AM
sammy77's Avatar
sammy77
Finally did mine yesterday, a total of 14 bulbs all together. I just went to my local dealership for them. From start to finish, about an hour taking my time really...
