I've always just snugged them down (probably less than 10 ft-lbs). I'll look and see if I can find something.
Don't forget to check the rocker arm pedestal bolts while you're in there. 20 ft-lbs.
Edit: Book says 9 ft-lbs on the deflectors
Thanks for the help. I found one post that said 10 ft/lbs but I just wanted to verify. I did retorque the rocker arms. Seems like every post I read about under the valve covers mentioned doing it.
