Draft tube
Old May 20, 2004 | 06:09 PM
steves59f100's Avatar
steves59f100
Draft tube
Hoping for a little help here. I am trying to locate a draft tube for my 59 f100 292 V8. I do have the top canister part, I am missing the flange and tube assembly, which mounts left side engine bottom of the block right behind the fuel pump. I have come up with three different part numbers no one can identify. I know somebody somewhere has one on the shelf!!!!!
Can anyone please help, even the correct part number would be a great start.
Thank You all!
Old May 21, 2004 | 07:07 AM
312's Avatar
312
you must have an older engine.the road draft tube on a 59 comes out at the rear.
Old May 21, 2004 | 09:26 PM
steves59f100
Thanks for the reply. As far as I know, this truck is all original, I bought it out of an estate, it sat 15 years after the original owner had the engine rebuilt, and never fired up.The engine was set back down in the frame and never completed.I am owner number three. The second owner was the grandson of the first owner.I have a copy of the 1959 title, all numbers as I see it match. All I need is this damn draft tube, and she's a daily driver. Do you have any ideas of where i may find this part. I was told the original part number is B8S 6758 then i was told it was a B5A 6758A.. none of which ford recognizes. It cant be that hard to find this damn thing, Thank you for your time in replying.
Steve
Old May 22, 2004 | 08:48 AM
312's Avatar
312
what you are looking for is a 54 57 item.the 59 has a pipe coming out at therear of the valley cover just behind intake.did you check there.
Cougar54
18
May 12, 2014 10:14 AM
Damifiknow
Nov 15, 2013 08:03 AM
65F100390
Nov 10, 2010 08:42 PM
spurredon
Jul 26, 2007 10:54 AM
MARC
Apr 3, 2000 09:11 PM
