1978 - 1996 Big Bronco
ABS problem
Old May 20, 2004 | 12:44 PM
lovemud's Avatar
lovemud
ABS problem
Hi folks!
I'm new here and was hoping I could get some tech help.
My ABS light is on, I've cleaned the brushes on the motor, I can make it run from the pin on the relay (#5) BUT, the relay isn't getting a signal to close. The fuses are fine, What else can I check or posibly reset? are there sensors on the rotors I might need to replace? What actually decides to send the signal?
I'm open to any ideas !
Thanks in advance!
-lovemud
Old May 20, 2004 | 09:30 PM
screwy's Avatar
screwy
How about pulling the codes?
Old May 21, 2004 | 08:45 AM
lovemud's Avatar
lovemud
Don't I need a programmer to pull the codes?
Old May 21, 2004 | 09:18 AM
screwy's Avatar
screwy
No, you can pull them with a simple paperclip. For starters, what year is your truck?
Old May 21, 2004 | 10:27 AM
kevhard's Avatar
kevhard
Here is a thread on pulling codes. Maybe this should be "stickied" to the top of this forum...
https://www.ford-trucks.com/forums/s...hreadid=112293
There are many other threads, including some with little diagrams showing where to stick the paper clip. Just do a search - Steve83 seemed to be the biggest contributor in this area, so you might want to search his posts.
Old May 21, 2004 | 01:12 PM
lovemud's Avatar
lovemud
Very handy, I wish I would known that last week when I took it in to have a throttle position sensor diagnosed.
Unfortunalely, I don't see any ABS codes listed, no codes no diagnosis.
The truck's a 95' w/ 351
Old May 21, 2004 | 02:18 PM
kevhard's Avatar
kevhard
Search the forum - ABS light comes up for discussion all the time. Might also check rear speed sensor on top of the rear diff.
Old May 21, 2004 | 07:17 PM
screwy's Avatar
screwy
If you come up with a code, I'll tell you what it says.
Old May 21, 2004 | 09:25 PM
lovemud's Avatar
lovemud
Thanks!
I'll give it a try this weekend and see if I can get a code.
Old May 24, 2004 | 08:38 AM
lovemud's Avatar
lovemud
Wink
I wasn't sure if this is done w/ ignition off or on, so I tried it both ways. w/ ignition off it did nothing steady on. if I started the engine if blinked 4 times and pu the engine to a high idle..
4 flashes must be the code for an incompetant tester
Old May 24, 2004 | 07:47 PM
screwy's Avatar
screwy
Haha... Did you use the red connector?
