General Automotive Discussion
Obsolte/Forgotten Procedures
Old May 19, 2004 | 08:57 PM
76supercab2's Avatar
76supercab2
Does anyone know of any procedures that were commonplace on early autos that we no longer perform any more. I'm thinking of things like:
1. Breaking in engine oil before driving any distance
2. Polarizing a voltage regulator on a generator equipped electrical system.
3. Setting a choke on a carburated engine before starting.
Any others with details? Anyone care to explain the ones I listed?
Old May 19, 2004 | 10:04 PM
68 351 bronc's Avatar
68 351 bronc
You should add cranking over the engine by hand with an actual crank.
repairing a wooden spoke wheel with stick found in a tree.
advancing the timing on a model T by hand.
Puting mother in law in the rumble seat so you couln't hear her bla bla bla. ,
Old May 19, 2004 | 10:06 PM
FTE Herman's Avatar
FTE Herman
How about the bearing adjustments when leather banding was used on main bearings? When I was a child and gaining an interest in vehicles and older gentelman was telling me about removing spacers and the leather bearing began to compress. Is this true?
Your number 2 may refer to energizing the 'field' before a generator would begin to produce current. Without the magnetic field the moving stator would not generate a current.
Your number 3. My 1971 Datsun had a manual choke.
Old May 19, 2004 | 10:37 PM
MisterCMK's Avatar
MisterCMK
Warming up a car with a carb for 10 minutes in the winter before driving off
Old May 19, 2004 | 11:35 PM
rusty70f100's Avatar
rusty70f100
Hey I still do that. Sitting in a cold explorer sucks.
My dad was telling me some stories about grandpa pulling the motor out of a model T, by hand, shimming the bearings, and putting it back in. In one day. Get it started on gas, then run it on kerosene.
Old May 20, 2004 | 12:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
Turning the windshield wipers by hand
Turning the windshield wipers by hand when vacuum was low.
Oiling the wiper motor leathers.
Tubes in tires.
Oil bath air cleaners.
Oil filter cartridges.
Toilet paper oil filters (these gimmicks still come back every few years)
Bypass oil filters
Water injection
Swamp coolers for car windows.
Splash lubrication.
Enclosed driveshafts
Enclosed leaf springs for lubrication.
Finding the gas tank filler behind a light or trim piece.
"Service" stations, and service station attendants.
Checking/filling battery water.
Honing brake cylinders and rebuilding them (they were cast iron).
Aligning and setting points.
Old May 20, 2004 | 01:53 AM
dono's Avatar
dono
Gone but not forgotten.
Adjusting tappets, mechanical brakes that required a strong leg, steering *****, fender skirts, windshields that cranked out, starting a tight engine with acytylene, running a speedometer backwards, removing door handles and using starter solinoids to open doors, split exhaust manifolds on inline engines, Columbia overdrives, Fordallacs, bypass oil filters, "Granny" gears, gasoline that was regular or Ethyl, Royal Triton - the purple oil, grease jobs, and my all time favorite - picking up your date, buying gas, seeing two features at a drive-in movie, cokes after the show (brought by a carhop), parking in the woods - total cost $2.50.
Dono
Old May 20, 2004 | 02:43 AM
tdister's Avatar
tdister
I was taught by my Grandfather to do the oil break-in. After changing the oil:
Start and make sure you have pressure, chech for leaks...
Drive it until fully warmed and then for another 5 minutes, drive back.
check for leaks/level...
Allow to fully cool before driving again.
A full heat cycle suposedly changes the oil a little, for the better. I've never heard of this anywhere else, so I'm not claiming this as fact. I would probably do this anyway just to check for leaks. Anybody? He also taught me to throw in a qt. of diesel oil w/ every change, and always use it to top-off in between. (perfect since I have a diesel that takes just over a gallon)
Most "maintenace free" batteries you can still add water to.
Old May 20, 2004 | 05:22 AM
bigjack's Avatar
bigjack
I had a 63 F100 with a 292 V8 and a generator. When replacing the voltage regulator you had to use a jumper cable or wire from the positive term. of the battery and touch a contact on the regulator to polarize it. Why it didn't come polarized from the factory I don't know.
Old May 20, 2004 | 06:46 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Rebuilding our own starters ,Allmost a two man job . Rebuilding master cylinder
and honing them, installing a 3 speed an using 3/4 inch extension with tape rapped around it to aline clutch and pressure plate.
P.S. My dad always told me that people that drove A and T models carried
cylinder sleeves so if they needed to rebuild the engine on the side of the
road they could hammer old ones out and hammer new one in.
Old May 20, 2004 | 06:51 AM
bigjack's Avatar
bigjack
Using hand signals for turning and stopping.
Old May 20, 2004 | 06:54 AM
nickmobile67's Avatar
nickmobile67
How about using lead for body work, instead of plastic filler. Rememer "Lead sleds"
Old May 20, 2004 | 07:03 AM
76supercab2
These are all great.
Anyone remember repairing innertubes? Find the hole, spread some goop on it, SET IT ON FIRE, blow out the flames, apply the patch. I think the heat activated the glue/caused the tube to vulcanize to the patch.
The voltage regulator couldn't be poarized at the factory because there is no electrical field in it while it is sitting in a box on the shelf. I'm sure if you removed one from the system and reinstalled it again you would have to re-polarize it.
Someone told me a story of driving a model T without breaking in the oil and the rod bearings went.
How about re-facing brake shoes for drum brakes.
Re-curving a distributor? I know it's still done but it's getting difficult to find people who can do it.
Old May 20, 2004 | 08:09 AM
propellerhead's Avatar
propellerhead
Sandpaper and contact points. Dam! That brings back memories.
Old May 20, 2004 | 08:16 AM
bigjack's Avatar
bigjack
Changing the oil in an oil bath air cleaner.
