General Automotive Discussion
Obsolte/Forgotten Procedures
Old May 20, 2004 | 08:40 AM
Big Orn's Avatar
Big Orn
Melting babbit to replace the bearings on the rods and crank.
Old May 20, 2004 | 08:42 AM
bigjack's Avatar
bigjack
Adjusting valve lifter clearance with a feeler gauge, while the engine is running.
Old May 20, 2004 | 09:39 AM
The Fife's Avatar
The Fife
Originally Posted by Torque1st
Finding the gas tank filler behind a light or trim piece.
Checking/filling battery water.
Aligning and setting points.
I still do these, along with the non-power brakes thing.
Old May 20, 2004 | 10:07 AM
Broncojohn's Avatar
Broncojohn
Adjsting valve to rocker clearance using a tool to compress the lifter, and a feeler guage.
Old May 20, 2004 | 10:37 AM
jim henderson's Avatar
jim henderson
Yup, replacing points and condenser. Adjusting tappets, rebuilding the carb, honing brake cylinders, changing the oil in the air cleaner. Replacing the "automatic" choke control, or adjusting the manual choke. Putting in a new filter element inside the filter can. Fixing the floor mounted high beam switch. Replacing hoses for vacuum windshield wipers, remember how they slowed down at the worst times?
Tuneups every 12,000 miles or less. Remember sand blasting spark plugs to save a little money? Still got my plug sand blaster.
I loved the old Swamp coolers. Dad had one for our trips thru the dessert, what a relief. Still see one every once in awhile on restored cars.
Remember the canvas water bags? Everyone had one or two on the front of their car if they were going thru the dessert. Anti freeze? What antifreeze. Change the water regularly and put in antirust.
Back seat bed kits that could be put in the car to make a bed for long distance travel. Pee bottles. Manifold cooking and old Coleman water jugs.
Push button transmissions and three on the tree.
Replacing water hoses on a schedule, often every 25,000 miles because otherwise they would blow. I can't remember the last time I had to replace a hose on any of my cars since the 80s.
Lots of nostalgia, but also thanks for the really great vehicles we have now. Modern vehicles run almost forever and hardly need any maintenance. Just oil and everyonce inawhile a tune up and coolant change.
Just some memories,
Jim Henderson
Old May 20, 2004 | 11:30 AM
dono's Avatar
dono
Gone but not forgotten.
Only to have it throw the rod again fifty miles later. I forgot that one.
Dono
Old May 20, 2004 | 01:23 PM
rebocardo's Avatar
rebocardo
Lighting your gas powered headlamp.
Old May 20, 2004 | 02:46 PM
1956MarkII's Avatar
1956MarkII
I can't believe no one else has posted this yet:
Starting the car, and having to wait for the radio tubes to warm up! It would take a while in the winter before we had tunes!
Old May 20, 2004 | 04:22 PM
68 351 bronc's Avatar
68 351 bronc
How about double clutching a non synchro tranny.
Or doing 70 mph, still in first gear of your power slide.
Old May 20, 2004 | 08:38 PM
76supercab2's Avatar
76supercab2
I think it's a garage procedure: Using a 'church key' to open a can of beer.
Old May 20, 2004 | 08:48 PM
3broncocrazy's Avatar
3broncocrazy
Soon to be "no more lead weights for tire balance"
Old May 20, 2004 | 09:24 PM
68 351 bronc
Is lead any more toxic than the dog urine on my brand new wheels?
Is it ok to open a can of beer at church?
Old May 20, 2004 | 09:31 PM
  #28
FTE Herman's Avatar
FTE Herman
Ok, what's a swamp cooler?
Old May 20, 2004 | 10:08 PM
  #29
76supercab2
A swamp cooler is an evaporative cooler. Usually uses water on a felt mat to hold the water. As air is passed across the felt the water evaporates and carries off heat giving a cooling effect. I'm not sure if that's how automotive coolers work. They look like a large can mounted in one of the side windows.
Re: "Is it ok to open a can of beer at church?"
It is at my church but that's a religious topic and we don't discuss that here.
I've always called those metal tools with a bottle opener on one end and a juice/beer can opener on the other a church key.
Old May 20, 2004 | 10:59 PM
  #30
1970f2504x4's Avatar
1970f2504x4
[QUOTE=76supercab2]3. Setting a choke on a carburated engine before starting.QUOTE]
Heh, still have to do this one
Here's another for the list:
"Fill it with unleaded, please"
