Cold weather
Old Nov 27, 2001 | 06:26 PM
Gr8ride's Avatar
Gr8ride
Cold weather
Howdy,
I have a 93 F250 7.3l diesel no turbo auto trans.
I was wondering at what temperature should I plug my
truck in. Also when I plug it in what is it heating?
And how long should I leave it plugged in?
Does it charge the batteries?
Thanks,
Gr8ride.
Old Nov 27, 2001 | 08:12 PM
0patience's Avatar
0patience
Cold weather
>truck in.
That depends on when it gets hard starting in the morning. Most the folks around here plug them in when it gets around 35 degrees.
It keeps the coolant heated, which warms the block.
Generally, it is left plugged in all night. It has a thermostat in it to keep the coolant at a specified temp.
No, it only heats the coolant.
Old Nov 28, 2001 | 06:51 PM
Gr8ride's Avatar
Gr8ride
Cold weather
Howdy again,
Just a follow up question.
I had a guy tell me that there
is a heating element in the fuel
filter assembly, it there any truth
to that.
Also when I start it up on a cold
morning, how long should I let it idle
before driving off? Just wondering, because
I heard someone say that if you don't let it
warm up enough something called "washing"
could mess up the cylinders.
Thanks,
Gr8ride :-)
Old Nov 28, 2001 | 07:24 PM
0patience's Avatar
0patience
Cold weather
> Howdy again,
>to that.
The heating element is a plate in the filter assembly head.
If you have an injector that is bleeding by, that could be a concern, regardless of if you let it warm up or not.
Our fleet, we recommend at least a 3 minute run time before they drive away.
Old Nov 29, 2001 | 08:47 PM
totalrecall's Avatar
totalrecall
Cold weather
Gr8ride
Aug 23, 2005 04:09 PM
Gr8ride
May 20, 2003 05:23 PM
Gr8ride
May 14, 2003 02:56 AM
Gr8ride
Apr 20, 2003 09:30 AM
Gr8ride
Apr 13, 2003 09:30 PM
