Keyless entry locks
Old May 19, 2004 | 04:33 PM
Michael45's Avatar
Michael45
Keyless entry locks
1999 Mountaineer V6. This morning I tried to enter using the remote. The lock mechanisum started cycling on all four doors. The cycling continued until I removed the fuse for that system. I let it set for several hours and still get cycling. Any suggestions?
Old May 19, 2004 | 05:24 PM
87 XLT's Avatar
87 XLT
Just a guess but i'd look at the door lock relay which is probably under the hood. Take a look at your wiring diagram it will tell you where the relay is located. I think there are 2, just swap them & see what it does.
Old May 20, 2004 | 07:53 AM
Michael45's Avatar
Michael45
Thanks for info. I have checked the Power Dis. Box under the hood. There seems to be relays for everything but the door locks! There is fuse[30 amp]. Will have to get my hands on a detailed wiring diag. Rechecked system today and still cycling. Doesn't seem to be an individual door lock mechanism.
It must be in the logic in front of the individual doors.
Old May 20, 2004 | 10:50 AM
stonem77's Avatar
stonem77
Probably the rear lift gate lock control at the rear driver side. These are known to accumulate moisture and cycle like you are saying.
Stoney
Old May 20, 2004 | 10:57 AM
stonem77's Avatar
stonem77
I meant the power lock control switch not the lock mechanism itself.
Old May 20, 2004 | 11:09 AM
87 XLT's Avatar
87 XLT
I was thinking 87 Ranger which reverses polarity thru the door lock motors with lock & unlock relays BUT i see in the Electrical & vacuum troubleshooting manual for my 95 Taurus that they simply use the door switches to reverse polarity. No longer using the relays. Check what stonem77 mentioned & if thats not it, maybe you have a stuck switch or short to ground somewhere. BTW, you can get the XLNT Ford electrical troubleshooting manual at www.helminc.com Good luck with it.
Old May 20, 2004 | 11:42 AM
Michael45's Avatar
Michael45
Thank all for info. The Power Lock Control switch seems to be involved in some way. If the cycling starts, I push down on UNLOCK and hold. The cycling will stop. The LOCK position is unresponsive, either on drivers side or the passenger side.
I will look into the manual mentioned.
If moisture, do you think there is chance that drying will restore proper logic??
Old May 22, 2004 | 01:09 PM
Michael45's Avatar
Michael45
Smile
Problem SOLVED-- One last check before taking to dealer. The rear control switch[rocker] was depressed by a recent cargo. Rocking the switch cleared the problem!! Thanks to all who responded.
Old May 22, 2004 | 03:14 PM
87 XLT's Avatar
87 XLT
OUCH -"almost went to the dealer"- that was a close call with having a much lighter wallet. Congrats on the fix
