2004 Transmission
Old Oct 7, 2005 | 07:02 AM
  #76
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Rickda, to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 7, 2005 | 02:17 PM
  #77
john bagley's Avatar
john bagley
Rick, if you go back to the beginning of this threa and follow it through, you'll hear about a lot of these things. Again, I would go to Infotraxx.com and sign up. For something like $12.95 they will give you access to all the service bulletins fior the car of your choice. These are not 'recalls". TSB's are for the dealer and say to him "oh by the way, if by chance a customer should come in complaining about this particular problem, here is where we screwed up at the factory and here's what you can try to do to fix our mistake". Don't know what you mean by "seal" but once when crawling under the car for an oil change, I saw leaking from the right front half shaft. Found out later there was a TSB about leaking half shafts.Yeah, how do you like that "no dipstick" on the transmission. When mine was shifting so bad (that's a TSB), I couldn't even check to make sure it had enough fluid in the transmission. They're getting like the government . They don't think you're capable of doing anything w/o their help.
lilshoe4me
Jul 2, 2014 07:30 PM
Big-Foot
6.7L Power Stroke Diesel
Jun 18, 2014 06:55 AM
thinksnow
Jul 14, 2013 01:12 PM
PaysonPSD
Jan 14, 2010 09:06 PM
