I'm an IDIOT!
Old May 18, 2004 | 10:14 PM
ltfox's Avatar
ltfox
I'm an IDIOT!
I did a stupid thing tonight. Pulled up to the fuel pump and put 40 bucks worth of premium GAS in my truck. Noticed what I was doing whe I hung up the nozzle. That will make ya feel stupid!! I pulled her home and now I gota get it out of their. I filled the front tank clear up with gas and topped the back off with no more than 1 or 2 gallons of gas. Any hints or tips on the best way to get it out. Do I have to get every drop out or what? I did'nt run on the back tank yet but is it ok to run with 1-2 gallons in there? Any help would be welcomed. Thanks
Old May 18, 2004 | 10:41 PM
topdogg's Avatar
topdogg
Responded to a thread on this a while back and it got pretty interesting!
The tank with the 2 gal. in it probably won't be a problem. Top her off with fuel and run it. The method I have used three times on three of our company trucks to solve this was... Disconnect the fuel line at the bowl. Connect a short piece of fuel hose to it. Connect an electric fuel pump to that hose. Put a piece of fuel hose, about 4 or 5 feet long to that and stick the end in a empty 55 gal barrel. Make sure the switch is on the bad tank. Turn on the electric pump. Remember your messing with gas! Don't use plastic hoses , or a plastic barrel, as static electricity can start a fire. Good luck. Don't swett it, your not the first, and won't be the last to do it.
Old May 18, 2004 | 11:17 PM
johnsdiesel's Avatar
johnsdiesel
I would recommend draining the tank. Read THIS link.
Old May 18, 2004 | 11:24 PM
ltfox's Avatar
ltfox
Thanks ya'll. Is cyphoning a good way and can you get enough of it out that way??
Old May 18, 2004 | 11:32 PM
johnsdiesel
The best plan (I hate to say this) is to drop the tank and drain the lines all the way up to the fuel bowl. Personally, I wouldn't get that carried away. You can use an electric pump, but be careful. I would also recommend adding Stanadyne Lubricity Formula and filling the fuel bowl with it along with a new fuel filter.
Old May 18, 2004 | 11:44 PM
ltfox's Avatar
ltfox
I never even tried to start the truck so it should'nt have any gas in the lines would it??
Old May 18, 2004 | 11:46 PM
johnsdiesel
No, they should be clean.
Old May 19, 2004 | 02:08 PM
rosa70's Avatar
rosa70
I was half way asleep when I put diesel in my gasser and didnt realize it until I got home and the truck was running like crap. Looked at my receipt 10 gallons of Diesel NICE> . Talk about being a DUMB A__ I went back to the store to top it off with more gas and I started to put diesel in it again. .5 gallons latter I woke up. My moto now is dont fill up any tanks the next morning after a long night or getting hammered.
Old May 19, 2004 | 10:10 PM
ltfox's Avatar
ltfox
Got my truck running tonight. Borrowed a pnematic diaphram pump and a couple of hoses from work and sucked the tanks dry and refilled them with diesel. Worked real good. Drove the truck around quite a bit on the tank that had mostly diesel and it ran greatn No problems. Thanks for all your help!
Krisverde
18
Jul 17, 2015 07:47 AM
El Camino Man
Feb 25, 2013 05:49 PM
86'F-150
84
Jan 22, 2013 10:33 PM
eatont9999
Sep 18, 2011 06:42 PM
castledrummer
Sep 14, 2007 07:16 AM
