Sponsored by: Real Truck
Best replacement U-Joints
Old May 18, 2004 | 06:15 PM
Fishin Technician's Avatar
Fishin Technician
I have this clunk when shifting from P to D.......with foot on brake....27,000 miles.......must be U joints....who makes the best greasable replacements.......02 / F350 / V10
D/FT
Old May 18, 2004 | 07:08 PM
MaXRSmart's Avatar
MaXRSmart
Spicer. I think you can get them at Napa.
Old May 18, 2004 | 07:45 PM
boxcar1974's Avatar
boxcar1974
I have found that sealed bearing last just as long and greasable. About 40 to 50K.
Old May 18, 2004 | 07:57 PM
03f350crew's Avatar
03f350crew
I thought the ones from the factory are spicers.
Old May 18, 2004 | 10:01 PM
FortyFords's Avatar
FortyFords
You should get more than 27,000 on u-joints!
Don't jump to conclusions ,it can be other things !
1)backlash in rear diff
2)slip joint in driveshaft
3)worn spider gears in rear diff
4 )rear axle bearings or splines on axle shafts
5) u-joints
6)chk your lugnuts also
7)internal trans problems (sun gears)
spicer is factory but non greasable
Rich
