HUGE electrical problem
Old May 18, 2004 | 04:42 PM
FordF250Newbie's Avatar
FordF250Newbie
Exclamation HUGE electrical problem
OK....heres the problem. Awhile ago, a Ford F-350 that has come into my possession had a body swap. This wouldn't be a problem, but someone put a '72 F-250 body on a '74 truck. I am using the originial wire harness out of a new '77 F-250 body i got. I connected the alternator, starter solenoid, etc. etc. I tryed to start the truck and I'm not even getting power to the dash. I have NO idea where to start... PLEASE HELP!!!!!!
Old May 18, 2004 | 05:26 PM
Jimbare's Avatar
Jimbare
all alone in the world
what do you mean no power to the dash? will it crank or anything?
jim
Old May 18, 2004 | 05:47 PM
toolz_not_toyz's Avatar
toolz_not_toyz
How do you know that wire harness is okay?
Old May 18, 2004 | 06:55 PM
GeneStoner's Avatar
GeneStoner
Battery installed?
Old May 18, 2004 | 07:54 PM
stanz's Avatar
stanz
Check your grounds. And be careful. If you don't have a good ground, the engine will make its own with the first wire it finds, and that can spell fire -- it happened to me once.
For $400, you may want to consider going with a brand new harness from Painless, Ron Francis or Centech.
Old May 18, 2004 | 11:16 PM
FordF250Newbie
There is no power anywhere on the whole truck, and yes, the battery is new and installed
Old May 19, 2004 | 12:13 AM
Mil1ion's Avatar
Mil1ion
Unwrap the covering on the main harness from the large stud on starter relay & check for a burned up Fusible link.
That's the only part of the wiring that would prevent power from reaching the fusebox from the battery.
Not having a proper ground would cause this as well.
Old May 19, 2004 | 08:24 PM
FordF250Newbie
While I'm at it, does anyone know where i can find a wiring schematic online??
Old May 19, 2004 | 09:09 PM
76supercab2's Avatar
76supercab2
Not online (ie free) but they are part of the manuals on CDROM available from the web store on this site. (IE helps support this site).
Old May 19, 2004 | 10:35 PM
Mil1ion's Avatar
Mil1ion
There are threads in this forum that contain wiring diagrams for starting & charging systems.
Use the search feature using the words " Charging system " or "Duraspark"
Old May 20, 2004 | 08:57 AM
toolz_not_toyz
I would recommend either the shop manuals from this site or a Haynes books or something like that. They will include wiring manuals but also explain how to fix a fusible link. Of course, I'm sure we all assume you've checked the obvious: that the new battery is actually carrying a charge.
Basically, start from the battery and work your way to the fuse panel.
