Aerostar Ford Aerostar
Fuel Injectors
Old May 18, 2004 | 04:26 PM
Wolflady's Avatar
Wolflady
Question Fuel Injectors
Could someone please tell me if your fuel injectors are out on a 1996 ford aerostar sport V6 3.0 L. engine would that cause the vehicle to backfire if the injectors were out?
Thanxs...
Old May 18, 2004 | 05:18 PM
copper_90680's Avatar
copper_90680
Injectors usually don't go bad all of a sudden and caused your engine to backfire. I'm quite certain you have crossed your spark plug wires. Check them three or four times, and then check them some more. Check them with your wife, check them with your friend, and then check them with your neighbors. The last time my brother had his engine rebuilt, the thing backfired and had blue smoke coming out just like what you described. My two brothers and I, with six eyes and three pairs of glasses, kept coming up with the conclusion that the wires were fine. We finally found out that two of the wires were crossed, but that's after a couple of hours. Those things can be hard to see, especially with no room under the hood.
Old May 19, 2004 | 02:27 AM
xlt4wd90's Avatar
xlt4wd90
A failed injector will usually shut down a cylinder, making the engine run rough. They don't usually fail with the injector stuck open.
Are there any check engine lights or codes from the EEC? It sounds like some sensor might be failing.
Old May 20, 2004 | 09:48 AM
L Ranger's Avatar
L Ranger
My 92 had a problem with the #2 injector. There was a short in the wirering and the injector would not work. My gas milage was way down arounf 11 mpg when the injector was bod but is now up around 17 mpg
