COLD STARTING
Old Dec 16, 2001 | 09:43 PM
EZ845's Avatar
EZ845
COLD STARTING
AFTER READING MOST OF THESE POSTINGS I CONCLUDED IT MUST BE MY GLOW PLUGS OR CONTROLLER. WENT TO PEP-BOYS GOT BOTCH GLOW PLUGS AND NAPA
FOR CONTROLLER 154.00 STILL NO BETTER. SHOULD I ORDER A WIRE HARNESS
FROM FORD A COUPLE OF THE INSULATION BOOTS WERE ROTTED SO I FITTED A SPARK PLUG BOOT ?? WELL IT WORKED I DON'T KNOW IF IT IS CORRECT.
MY PROBLEM IS VERY SPICIFIC COLD STARTING. THIS MOTOR TURNS RIGHT
OVER WHEN ITS WARMED UP.
IT DOESN'T NEED TO BE ACTUALLY COLD OUT THOUGH IT COULD BE 60 DEGREES
IF I DON'T PLUG IT IN IT WON'T START.
IF I PLUG IT IN IT WILL ROAR!
92 INTERNATIONAL MOTOR IN 89 FORD F-350 ROLL BACK FLATBED
Old Dec 20, 2001 | 07:04 AM
turbolover's Avatar
turbolover
COLD STARTING
I have a 97 PSD and I had the same problem. I took it to for and they said I had 3 glow plugs that were not heating up, they relaced it and while I was living in TX and since then I have moved to MI. and have not pluged it in yet.
Kyle
Old Dec 20, 2001 | 01:57 PM
rrooney's Avatar
rrooney
COLD STARTING
Hmm, new plugs and relay. My problem was the relay but I also have two bad glow plugs. After replacing the relay it starts but chugs a little before warming up.
How long does your "wait to start" light stay on when cold? Check out the cold starting troubleshooting post, it has some tests that may help you.
Randy
95 PS crew cab
Old Dec 20, 2001 | 07:53 PM
EZ845's Avatar
EZ845
COLD STARTING
THE TRUCK HAD ME BAFFOLD SO I SENT IT TO A LOCAL MOTOR HEAD.
IT WAS ALTERNATING ITS CRANKING WITH THE ENERGIZING OF THE GLOW
PLUGS. SEVERAL MICS. LOOKED AT AND NEVER SAW THAT BEFORE..
WELL THEY DETERMINED SOMTHING IN THE IGNITION SWITCH WAS THE CULPRET
LIKLEY REASON WAS AN ALARM SYSTEM FROM FORMER OWMER.
ALSO THE NEW CONTROLLER WAS BAD IT WAS STAYING ON TO LONG AND BURT
OUT MY ALSO NEW GLOW PLUGS. HE'S NOT SURE WHY THE PROPER VOLT'S
ARE GOING IN, NOT COMING OUT.
HE TOLD ME TO COME PICK IT UP ITS DONE
I'VE NEVER BEEN SO UNSURE SO I'M GOING TO WAIT TILL MORNING
WHEN ITS GOOD AND COLD
LIST OF PARTS THIS WEEK
2 SETS OF GLOW PLUGS
2 CONTROLLERS
WIRE HARNESS
130 AMP ALTERNATOR
NEW BELT
2 INTERSTATE 950 CCA BATTERY'S
IGNITION SWITCH PARTS
MISC PARTS
Old Dec 20, 2001 | 08:02 PM
Monsta's Avatar
Monsta
Sit. Stay.
COLD STARTING
Man EZ845, sorry to hear 'bout your troubles! Not a good time of the year to go replacin' all that stuff. Hope it all works out well for ya. Incidently, my old 6.2L (GM boat anchor) never had more than 5 plugs workin' in it's life with me. But with h*ll strong batteries I never had a problem until it got down to below freezin'. I see you replaced your batteries, good.
Good luck and Merry Christmas!! :-X12
Old Dec 24, 2001 | 09:30 AM
EZ845's Avatar
EZ845
COLD STARTING
Problem fixed.. Thanks all mery cristmass to all
turned out security system was giving intermintate contact
bad controler NAPA returned an electrical part which they
did not have to do. they trated me great there. three glow
plugs were not making contact.
i went out there this morning it was 35 degrees...
not plugged, it started right up sounded rough but that
is to be expected. thanks all i have learned more on this
site than any other:-X12
Old Dec 24, 2001 | 11:26 AM
Latebloomer's Avatar
Latebloomer
COLD STARTING
