plug wires... boots ?'s
Old May 18, 2004 | 02:56 PM
cleanLX's Avatar
cleanLX
picked up the parts to do the large cap conversion at noon(85 mustang stuff... neat).
I'd really like to run some Ford Racing wires, but no one lists a part number for an FE application.
Are you guys running small block wires, or big block wires, and what are you running for boots? 45*, 90* straight?
I've got stock logs now, but will 'eventually' thro some FlowTechs on.
Summit told me I should grab a set for a 460... dunno?
Old May 18, 2004 | 06:53 PM
cleanLX's Avatar
cleanLX
well...
cannot seem to get an answer anywhere, and no one (Ford dealers) stocks Ford Racing 460 plug wires anyway.
I have a set of Ford Racing wires for my '92 5.0 Mustang that I'll not be useing for a while, so, I think I'll see if those will fit.
Old May 18, 2004 | 09:14 PM
BB's Avatar
BB
I'd go with the 460 wires, I think the small block wires will be too short.
Nobody stocks them, sheesh!
IMO the 45 and 90 degree boots look goofy.
Old May 18, 2004 | 10:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Uhhhhmmm, the "racing" wires will not make you go faster... Just use a good stock set.
Old May 18, 2004 | 11:36 PM
cleanLX's Avatar
cleanLX
I'm not trying to go faster, thanks tho.
I'm trying to rid the truck of a miss, so I can pass emmissions... and the Autozone cheapo's I have on there now are litterally falling apart.
For an update...
The 5.0 wires with 45* boots fit like a glove, however, there is no way to connect to the coil.
My truck sits in the driveway useless... all for a coil wire that works with the big cap conversion, and the stupid female coil interface.
Old May 19, 2004 | 10:50 AM
kwanderi's Avatar
kwanderi
I installed the large cap on my 65 352 and used a set of Bosch 8.5mm wires from Autozone. The set came with two different styles of the coil wire and works great.
I think they were for a mid 80's model.
Keith
Old May 19, 2004 | 12:33 PM
cleanLX's Avatar
cleanLX
that would have been nice... the 2 coil wire deal...
since I have no clue how old the coil is, or what shape it's in, I'm going to go ahead and grab an msd blaster 3... it's got the required spark plug type post on it... and is cheaper than a set of wires.
new plugs, new 'big' cap and rotor, new wires and new coil... hopefully that cures the miss.
Old May 20, 2004 | 01:46 AM
cleanLX's Avatar
cleanLX
well.
no luck, same miss... guess that is why I'm not a mechanic.
The dizzy is a stocker, and likely a million years old.
Only things that have not been replaced in the ignition department are the condensor, and the dizzy itself.
Another thing that is strange, is, I can set the points on Saturday, and by Wednesday they are fubar'd again.
Why would my points continually go out of adjustment in such short order?
Am I facing a case of a plain old wore out dizzy?
I don't get it.
Old May 20, 2004 | 07:37 AM
fordman428's Avatar
fordman428
id get a factory duraspark ignition that came on the later ford engines, it sounds like your old point type dizzy is getting on its last leg.
