400 mods
Old May 18, 2004 | 10:54 AM
Josh79's Avatar
Josh79
400 mods
i have built a 400 out of a 351m and i have some more money i want to put into it and i need to know what would be the best thing for it next. i bored and stroked the 351m to be a 410. It has an edelbrock performer manifold w/ a 750 holley carb. also comp cams 268 cam. i am getting heddman elite headers for sure so what would be the next thing to do to get more power for a decent price? im thinking either ignition or roller timing chain. suggestions on what to do and companies to get it from will be appreciated.
Old May 18, 2004 | 12:03 PM
freak98's Avatar
freak98
Do the ignition,go with the MSD setup.
Old May 18, 2004 | 06:49 PM
danlee's Avatar
danlee
The ignition is OK, but while you have it apart you should do the internals, like double roller timing chain (Cloyes is one). Another is roller rockers like Scorpion. You can run the stock ignition until you can upgrade.
Old May 18, 2004 | 08:39 PM
bubbaf250's Avatar
bubbaf250
Neither ignition nor the timing chain will give you more power. (Not that both aren't worthwhile for other reasons.)
Which pistons do you have? Higher compression will allow you to get a lot more from the induction/exhaust mods.
If you've done everything else already, how about porting the heads?
Old May 18, 2004 | 10:38 PM
Josh79's Avatar
Josh79
already have roller rockers also forgot that. maybe porting heads is the way to go. ill have to ask around and find a good shop. how much should i expect to pay for porting heads?
351Cleveland C4
May 13, 2014 09:32 AM
351Cleveland C4
May 15, 2013 12:49 PM
colton04mclean
Oct 29, 2012 02:02 PM
blackbettybronco
1978 - 1996 Big Bronco
Oct 5, 2010 07:52 PM
77_F150_4x4
Feb 16, 2005 12:58 AM
