Sponsored by: Kumho
Lowering Questions
Old May 18, 2004 | 10:31 AM
superman71's Avatar
superman71
Lowering Questions
I need some help i have a 71 shortbox ford f-100 and i want to lower it 3 inches all around. what are lowering blocks and do they work well. I can just use shakels to right. just give me some info on all of this stuff and how they work. Thanks alot.
Old May 18, 2004 | 03:59 PM
daddzwaterboy's Avatar
daddzwaterboy
Talking
Probably new I beams in the front for 3", new beams are about $500.00... For the rear, you would probably want it to sit level??? So you should go lower than 3" in the rear... You can flip the springs and pu them under the axle and c notch the frame, I think you should get 6-7 inches there?? Its pretty cheap to do... i will be doing this set up within the next six months...
Mike
Old May 19, 2004 | 08:11 AM
superman71's Avatar
superman71
I wasnt wanting to replace the i beams i was just thinking shackles in the back and lowering springs in the front. And about lowering the back more than the front to keep it level i have air shocks on the back and it sits level right now. But i have another question. I have 275/60/15 tires all the way around my truck with 10" rims; if i lower my truck 3 inches will my tires rub. I really need an answer. Thanx.
Old May 19, 2004 | 10:43 AM
daddzwaterboy
I think you can only get 2" coils for the front??? As far as the rub, I gots no idea... My truck is still sitting there waiting for a new engine...
