Sponsored by: Auxito
rebuilt 4.2L problems
Old May 17, 2004 | 02:54 PM
BrokenSockets's Avatar
BrokenSockets
I just got a rebuilt 4.2 in my F-150. It is mostly working, but at idle and when putting it into gear, starting from a stop, etc. it hesitates and runs rough. Sounds like it is going to stall. Once I get moving it sounds fine. Just had a shop run through anything they could think of and had it hooked up to a code scanner.
It shows intermittent missing, all o2 sensors are giving readings withing the right range. They are suggesting possibly EGR valve or cam sensor. If it is cam sensor, wouldn't it run rough at all speeds? Would a bad EGR produce these symptoms?
In any case, they cleared the computer and told me to drive for a couple days and see what comes up. They also complained about the 97 computer not being descriptive enough.
Any Ideas?
(also listed in 4.2L engine forum).
Old May 18, 2004 | 01:02 AM
Racerguy's Avatar
Racerguy
Was the cam position sensor/synchronizer assembly lined up with the special tool when it was installed?
Old May 18, 2004 | 06:19 AM
BrokenSockets
Special tool? Don't know. Engine was a rebuilt, long block, installed by a shop in town.
Old May 18, 2004 | 08:21 AM
Racerguy's Avatar
Racerguy
I would ask them how they lined up the cam position sensor/synchronizer assembly.
It has to be done right or you can get symptoms like you have.
Chances are pretty good that only your dealer has the tool needed to do it.
Harry Thompson
1997 - 2003 F150
Aug 28, 2009 07:48 AM
TboneThom
3.8 & 4.2L V6
Dec 8, 2005 12:59 PM
l965mustang
1997 - 2003 F150
13
Mar 5, 2005 11:03 AM
BrokenSockets
3.8 & 4.2L V6
16
May 19, 2004 11:56 AM
cabc23
1997 - 2003 F150
Jul 4, 2003 06:51 PM
