Backfiring
Old May 17, 2004 | 02:17 PM
fmc400's Avatar
fmc400
MSEE
Backfiring
Hi all,
On my '73 400, after I start the motor and punch the gas with the engine cold, it first starts revving like it should but then it bogs down and backfires. It only does this when it's cold. After a few minutes it is back to normal.
My timing is around 10 degrees BTDC. Could the timing be the problem, or is my choke too lean or too rich? The choke is at 3-rich, perhaps the choke pull-down is too wide?
Thanks
Old May 18, 2004 | 09:29 AM
ashvalentine's Avatar
ashvalentine
You could peg the choke plate full open and start it cold and see what happens.
You've got a cold miss and then some air is getting in from somewhere and you've got the backfire. Without any other info to go on, the straight-forward thing to do would be to do a cold compression test, followed by a hot one to make sure you haven't got a bad cylinder.
ash
['Sounds annoying.']
Old May 18, 2004 | 07:37 PM
danlee's Avatar
danlee
Sounds rich to me. The plugs are loading up and gas is passing into the exhaust manifold. Then as Ash said you have air and fuel and heat, then it backfires.
I would lean the choke setting and try it.
