Aerostar Ford Aerostar
Strange idle "serge" when cold
Old May 17, 2004 | 09:23 AM
moneyPit's Avatar
moneyPit
My '94 3.0L has started to "serge" on a clod start. It will start fine and idle ok for a second or two, Then it drops down to almost a stall, then back up to normal and so on. It will usally go away after it warms up a little or if you give it the slighest amount of gas for 30 seconds. If you just ignore it and drive off, it usally also stops (i.e. runs fine). The odd time it will stall, but restarts okay. with 304000Km, it is alittle tired, but runs fine.
Any ideas?
Old May 17, 2004 | 09:32 AM
AeroBay's Avatar
AeroBay
I would clean airbypass valve or replace it, it sounds like it's not functioning well. Good luck.
Old May 17, 2004 | 09:44 AM
moneyPit's Avatar
moneyPit
If you mean the airbypass valve used with the AIR pump, I don't have one. (maybe for CA emmisions) If not , what do you mean by "airbypass valve"?
Thanks.
Old May 17, 2004 | 10:16 AM
AeroBay's Avatar
AeroBay
It's also known as the trottle control valve, And it seats on top of the intake with a solenoid attached to it. I don't beleve the Aerostars came with an air pump (well maybe a 2.3 L ?). You need to unbolt 2 screws and clean it up real good with an air intake cleaner to take all that gum out. Anyhow do a search for "Air bypass valve" or "trottle control valve" in this forum and you'll find plenty of posts on how to check and clean this baby.
Good Luck.
Hector.
Old May 17, 2004 | 10:45 AM
moneyPit's Avatar
moneyPit
I didn't think they had AIR pumps!, Anyway, now I know what you mean - looks like a common problem after searching around. I will give it a try.
Thanks
Old May 17, 2004 | 06:32 PM
eehoepp's Avatar
eehoepp
This part is also known as the Idle Air Control valve (IAC)
Cheers,
Eirc
Old May 18, 2004 | 06:01 AM
moneyPit's Avatar
moneyPit
so many names for one part! - Anyway I cleaned it up and it seems good now.
Thanks again
Serg
Dec 28, 2013 05:58 PM
rehpig
18
Apr 26, 2012 09:13 AM
twp
1997 - 2003 F150
Dec 16, 2011 10:55 PM
bigb609
Oct 23, 2011 08:01 AM
BDSSUperDuty37
Nov 29, 2010 08:42 PM
