Carb Combo (351w)
Old May 17, 2004 | 04:50 AM
jsslasj's Avatar
jsslasj
Question Carb Combo (351w)
I Have A 1984 Ford F-150 4x4 With A 351w (2-barrell). I Would Like To Put A Good Hi-performance 4 Barrell / Intake Combo On It. If Someone Could Help Me Out And Let Me Know Whats The Best Wat To Go? Thanks, Also I Am Trying To Find A Set Of Perfect Fit Headers For The Same Engine. Help, Thanks Again
Old May 17, 2004 | 07:04 AM
jwtaylor's Avatar
jwtaylor
What do you mean by perfect fit headers?
If its shorties then call summit 1-800-230-3030 or jegs 1-800-345-4545 they should have what you need. If by perfect fit you mean not crap, then get a set of long tubes, they are a little better at developing low end torque, this does require you modify or have your exhaust modified.
edelbrock performer intake and ebelbrock performer 600 cfm carb is what I use and it does fine. My next venture will be a weiand stealth intake and either a holley or demon carb (in the 625-650 cfm range), so I would suggest that, I have used holley carbs they are fine, the weiand intakes I have used those as well and liked'em, demon I have never used but being its a holley carb thats been accessorized, haha, and given others feedback it should be a good piece with some tuning, everyone says out of the box the demon needs to be tuned, but once the bugs are worked out its great, the edelbrock I use didn't require anything more than idle mixture screw adjustment, which every carb needs, I switched out the metering rods and jets and played with it and the stock setting was fine. Its a stock 351w like yours. Who knows? Good luck with your decision
Old May 18, 2004 | 01:32 AM
svgearhead's Avatar
svgearhead
If you want torque (important for trucks), look for something like the Edelbrock Performer intake and a Holley truck Avenger. They probably match the factory cam better too.
I've the Edelbrock Performer, a Street Avenger, a 260H cam and Mustang shorty headers on my '69 F100 351W and it RUNS!
Old May 19, 2004 | 06:34 AM
jsslasj's Avatar
jsslasj
Thanks for the info very much jwtaylor, by perfect fit, I mean no mods needed.
Old May 19, 2004 | 06:36 AM
jsslasj's Avatar
jsslasj
Thanks alot for your help svgearhead.
Old May 19, 2004 | 07:18 AM
jwtaylor's Avatar
jwtaylor
Yeah give summit or jegs a call they should have shorty headers that will work.
Old May 20, 2004 | 12:14 AM
jsslasj's Avatar
jsslasj
I sure will jwtaylor, thanks again.
cjben
Nov 25, 2004 10:16 AM
forddytube
Mar 15, 2004 11:25 AM
Stingray42
Jul 15, 2003 11:33 AM
ihregistry
May 31, 2003 09:44 PM
cjben
Apr 2, 2003 04:10 AM
