Modular V10 (6.8l)
Ignition Coils
Old May 17, 2004 | 12:35 AM
RohnP's Avatar
RohnP
Question Ignition Coils
Does any know of aftermarket ignition coils for the 6.8 V10
Old May 17, 2004 | 12:46 AM
MustangGT221's Avatar
MustangGT221
We have a V-10 forum here on the site, this forum is not ment for automotive discussion, thanks
Old May 17, 2004 | 09:53 AM
jasontrucks76's Avatar
jasontrucks76
I thought this was the V-10 forum???
Old May 17, 2004 | 10:24 PM
HeavyAssault's Avatar
HeavyAssault
Being that this is the V10 forum, you post is on topic. As far as I have looked I haven't found a replacement aftermarket performance C.O.P system.
Old May 18, 2004 | 01:06 PM
ken04's Avatar
ken04
Since they're individual units, unlike say a V-8 distributor, I wonder if an aftermarket set from a 5.4 or even a hotrod 4.6 mod motor would work ? What exactly does the COP do besides send a spark to the plug ? The actual timing seems like it's probably done somewhere else on the engine, so I would guess that all the COP unit does it send an electrical current at the right time to the plug. Does anyone know it our engines are sequentially fired or batch fired ? I sorta understand the difference I think. Doesn't batch fire send sparks to the plugs in every cylinder when they fire one cylinder ? Because (I'm assuming) the other 4 cylinders are somewhere in the stroke cycle that a spark doesn't affect them. Or am I missing something ?
Old May 18, 2004 | 02:44 PM
Monsta's Avatar
Monsta
Sit. Stay.
He moved this thread from the General forum.
Old May 18, 2004 | 03:35 PM
airtractrdrivr's Avatar
airtractrdrivr
Anyone compared the part numbers of a stock V10 coil pack with a stock 5.4 or 4.6 coil pack? If they are the same, then the aftermarket packs should work. I wasnt aware that the 5.4s and 4.6s had the COP setup.
Old May 18, 2004 | 03:50 PM
airtractrdrivr
part numbers..
I looked at a stock coil pack off a '01 Mustang Cobra 4.6, and here are the numbers on it:
first row: EED (or B, couldnt tell for sure) 3A
second row: 1L2U-12A366-AA
third row: 282053
I think these are right, I was looking at a picture of the top of the coil pack
Old May 18, 2004 | 04:26 PM
jasontrucks76
Thanks for explaining!! I am still new and diddnt catch that
Old May 19, 2004 | 04:50 AM
V10man's Avatar
V10man
Did a quick search at Autozone and they show coils for the V10.
Old May 19, 2004 | 08:30 AM
BigRedTruckTX's Avatar
BigRedTruckTX
Autozone coil packs are 40.00 a piece (as of 3 days ago).
Old May 19, 2004 | 08:32 AM
airtractrdrivr
Those are stock coils...
I think the question is, will any of the aftermarket performance coils match up and work on the V10. OR, maybe I just read the question wrong, and he is looking for stock coils that are cheaper than the OEM Ford coils, heck, I dont know!
Old May 19, 2004 | 09:02 AM
gmsux's Avatar
gmsux
What would you expect to gain with a "hotter" coil pack on an otherwise unmodified combustion process? Typically oem ignitions are very good for the application and with plenty of capacity for fairly extensive modifications.
Old May 19, 2004 | 10:02 AM
airtractrdrivr
Dont know. The OEM coils seem to work fine for me, and I've got several mods done. You know how it is though, performance nuts cant leave anything alone for long!!
Old May 19, 2004 | 11:02 AM
gmsux's Avatar
gmsux
That's the truth! I've been modifying fords since I was 16 and I have spent my share of money on parts! I'll say this, I've learned that ignitions really are'nt an area of power. Yes you need them to function properly but really, that's about it. Through many dyno sessions and years of racing the Power of an engine comes down to primarily three things... Cam, Heads, and intake. Reason I bring this up is that I don't want to see folks buy 10 coil packs thinking this will provide a solid hp gain. This is experience talking friends!!
