Doing IPR o-ring kit questions
Old May 16, 2004 | 10:33 PM
rosa70's Avatar
rosa70
I have decided to do the IPR o-ring kit for my 99 model cause of the hard starting problem. I need to know if anyone knows the part number for this kit from international and Ford. Also when I suck the oil out of the HPOP reservoir do I need to fill it back up after and do I use normal Diesel Motor Oil. Thanks..
Old May 16, 2004 | 10:40 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Don't know the dealer part numbers, but I saw a good price on the kit HERE
You will need to re-fill the reservoir with engine oil prior to re starting the truck.
Old May 17, 2004 | 08:19 AM
rosa70's Avatar
rosa70
Before I buy the kit can I just pull out the IPR valve and check it out to see if there is any splits in the orings. Or when I pull it out will I tear up the o-rings? Im only doing this cause of the hard starting when hot and I read some threads where the IPR valve can cause this. Let me know...
creator
May 12, 2012 10:58 AM
ron's power stroke
20
Dec 8, 2011 02:11 PM
mark460
Oct 6, 2011 09:24 AM
landstorm
Feb 27, 2011 09:34 PM
dieselboy427
Aug 12, 2009 11:32 AM
