trading a chip
Old May 16, 2004 | 10:13 PM
f350xlt460's Avatar
f350xlt460
trading a chip
A buddy of mine just bought a 99 350 7.3L (just 5 months new then mine) and is looking for a little more power. I have a superchip chip that im not using now. Would there be any concerns with letting him use the chip?
In other words, since hes a lariat ex cab 2wd, and im xlt crew 4wd, will that make a diff?
(computer calibration codes are the same)
Old May 16, 2004 | 10:31 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The only thing that matters is the PCM calibration, since your two trucks are the same I don't see a problem. What HP tune is the chip? You are going to tell him he needs gauges before you let him go tearing around town...right?
Old May 17, 2004 | 03:12 AM
Quadzilla's Avatar
Quadzilla
Friends don't let friends drive trucks with a chip and no gauges.
Old May 17, 2004 | 05:45 AM
f350xlt460's Avatar
f350xlt460
well, the gauge point is very true.
When i first bought the truck used, it had this chip in it and i dorve cross country with it, not aware the truck was chipped pulling nearly an 8k load.
Stock intake, stock exhaust.
Not saying i did the truck any good, but its still running strong 20k later.
Dont worry, i will advise him on at least pyro and maybe boost.
Old May 17, 2004 | 09:38 AM
wlihntr's Avatar
wlihntr
doesnt the computer code on the ECU have to be the same as well. i thought that even the same model and year could have different codes.
Old May 17, 2004 | 11:10 AM
cookie88's Avatar
cookie88
FTE Emeritus
Dunno, what's an ECU?
Old May 17, 2004 | 01:54 PM
wlihntr's Avatar
wlihntr
electronic control unit (the computer), when i have ordered chips they always asked for that code, it is on sticker on the inner front drivers door jam, and it is also on the barcode sticker on the computer case, for instance the code on my truck(i think one company refered to it as a capture code) is PMT-1, and any of the cips i have got said PMT on the chip
Old May 17, 2004 | 07:15 PM
CAT_man_963's Avatar
CAT_man_963
I think you guys are referring to the same thing, just with different terms!!!
Old May 17, 2004 | 08:25 PM
bender97f250's Avatar
bender97f250
Yes,before getting my chip burned from Banks,I had to give them a sequence of letters and numbers similar to a vin #.
Old May 17, 2004 | 09:17 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yep....we're talking about the same thing, the Powertrain Control Module.
Old May 17, 2004 | 10:45 PM
wlihntr's Avatar
wlihntr
thats funny, when i worked in home electronics sales PCM stood for "plus code modulation"(its a form of digital audio recording), i got the term ECU from having work done on my merc. opti-max outboard, they had to replace the ECU and when i asked what that was i was told the Electronic cotrol unit, like the computer in your truck
