Sponsored by: Real Truck
Turn signals on hyper speed
Old May 16, 2004 | 09:06 PM
hemiman57's Avatar
hemiman57
I have an 04' f-250 4x with a service box on it for a work truck, I swapped the tail lighs over to the new LED type. now the turn signals are blinking at a extreme speed, it's almost like the flasher is overloaded. the 4 ways work fine they have different flasher unit. ford doesn't offer any replacement flasher units nor does napa any Ideas?
Thanks
Old May 16, 2004 | 09:15 PM
03f350crew's Avatar
03f350crew
Mine did this but it was because the bulb fell out of the socket. I put it back in and back to normal.
Old May 16, 2004 | 09:52 PM
pops_91710's Avatar
pops_91710
The flashers are designed to work with bulbs that burn a filament. Diodes have no filaments because they are, well, diodes! They have almost no resistance.
Because the operation of the flashers is dependent on the current flow through them, any change in the voltage applied will also have an effect on the flash rate.
Increased resistance makes a slow flash rate, conversely, decreased resistance speeds up the flash rate. You will need to increase the in-line resistance to the lights, (which defeats one of the purposes for using LED's, i.e. low energy consumption).
Check with a trailer supply for which type of flasher works for LED's. You may have to go to a mechanical intervalometer.
Old May 16, 2004 | 09:59 PM
refuse2's Avatar
refuse2
What about switching over to a mechanical flasher verus a electronic flasher? I had heard of some people having to do this to get them to work right.
refuse2
Old May 16, 2004 | 10:01 PM
pops_91710's Avatar
pops_91710
Check the last line of my post above yours!
Old May 16, 2004 | 10:12 PM
SoCalDesertRider's Avatar
SoCalDesertRider
When I switched over to LED tailights I had to switch to a 552 flasher and that took care of all flasher issues. It's also louder than the stock one so I can hear it through the radio and the wind noise. Didn't cost much and got it at Kragen.
Old May 16, 2004 | 10:17 PM
pops_91710's Avatar
pops_91710
There you go! I love this site!
Old May 16, 2004 | 10:36 PM
hemiman57's Avatar
hemiman57
Thanks for the quick responses, changing the resitance of the tail light had crossed my mind. I pulled the flasher unit out to get the part #'s on it and was suprised to find it had 5 leads and it seems they're all wired, the tail lights were supposed to be direct replacements for the bulb type , so much for the easy way!
Thanks again
Old May 16, 2004 | 10:58 PM
hemiman57's Avatar
hemiman57
I may have found an answer to this problem: http://www.mesa4x4.com/tech_articles...r/flasher.html
I'm going to pull the flasher later and see if it is like the one in this article.
