when i get my 351 Windsor EFI warm, it likes to shoot oil out of the damn dipstick, making a huge mess, any idea what the hell is causing this?? thanks
Blowby is combustion gasses blowing past the piston rings into the crankcase due to wear or stuck/broken rings.
The PCV (positive crankcase ventilation) system draws air through the crankcase through a PCV check valve into the intake manifold. Fresh air enters the crankcase through a breather filter. If any of this gets clogged, pressure can build in the crankcase and could force oil out the dipstick.
The Chilton and Haynes manuals explain this thoroughly and show the component locations. Good luck.
i took the black hose that comes from the oil fill cap and leads to the air filter box, it was CLOGGED with this white stuff, it looked like bacon fat, and she dont spray out oil anymore, thanks guys
You may get by replacing the black little plastic gizmo at end of the hose but eventually the white stuff will come back. You'll need to have reason for water in the oil checked sooner than later.
