reverse lights
Old May 16, 2004 | 02:02 AM
ford390gashog's Avatar
ford390gashog
Exclamation reverse lights
could someone tell me how to adjust when the backup lights come on i have a colum shift someone told me i could adjust it on the colum is this true help me
Old May 16, 2004 | 09:53 AM
ecarter50's Avatar
ecarter50
What year and what trans? Some have the switch on column, some are on trans.
Old May 16, 2004 | 03:24 PM
ford390gashog
it is the 1975 ford f 150 supercab with a c 6 trans
Old May 16, 2004 | 05:09 PM
ranger429's Avatar
ranger429
Reverse light switch is on the trans, I have never heard of an adjustment for them as they work by the transmisson putting pressure on the ball on the end of the switch in the trans and convert's it over to a ground? I think, to turn on the reverse light's.
Old May 17, 2004 | 11:35 AM
tbirdrief's Avatar
tbirdrief
I have a 1976 250 with a C6 and my adjustment is on the top side of the lower end of the colum. There are two screws that need to be loosened, then slide the switch. Be careful, this switch also controles the starter lockout and it could start up in drive. In many cases this switch gets warn out and needs to be replaced. Good luck.
Old May 17, 2004 | 02:48 PM
dfisher1's Avatar
dfisher1
The ranger is a little off on his diagnosis. I believe the 78 & 79s have the neutral safety switch on the tranny, all others have them on the column. Mine do, at least. The neutral safety switch is in the cab at the firewall. It is on top of the column. There is a small metal finger/tab that sticks out of the column and actuates the neutral safety switch. Check for this first. Chances are it just fell off. If it is there, check for power to the switch. If there is power, replace the switch.
Good luck,
KingFisher
Old May 17, 2004 | 03:15 PM
ranger429's Avatar
ranger429
OOOPS!!! I guess I assumed (bad mistake, won't do it again) LMAO that the early model's were the same as the 78-79. I still did not know that they incorporated the N/S switch with the reverse light's, I thought all had a seperate switch on the tranny. My BAD
Old May 17, 2004 | 11:00 PM
Mil1ion's Avatar
Mil1ion
Old May 18, 2004 | 02:14 AM
ford390gashog
which 2 screws do i need to loosen and how do i calibrate the switch
