Oil & Lubrication
My Blend
Old May 15, 2004 | 08:10 PM
BlueOvalFitter's Avatar
BlueOvalFitter
My Blend
What do you think of my blend? 4 quarts of Havoline 10W30 dino and 2 quarts of Havoline 10W30 synthetic oil.
Old May 15, 2004 | 08:38 PM
johnsdiesel's Avatar
johnsdiesel
How does it run?
Old May 15, 2004 | 09:51 PM
BlueOvalFitter
Actually,I cant really tell.But,I figure since no oil companies will reveal how much synthetic oil is actually in synthetic blend,I would just make my own.They could add as little as 2 drops of synthetic to a dino oil and call it a blend.My blend,I know how much is in it.
Old May 15, 2004 | 10:26 PM
stevieweevie's Avatar
stevieweevie
personally i would go with full synthetic ....i believe in going First Class or no class at all
Old May 16, 2004 | 12:16 PM
peppy's Avatar
peppy
Thats my problem. No class at all.
Old May 16, 2004 | 01:31 PM
BlueOvalFitter
Yeah,I guess I have no class at all!
Old May 16, 2004 | 02:36 PM
johnsdiesel
Same here, no class. My truck seems to like the "no class" Rotella T dino oil.
Old May 16, 2004 | 05:49 PM
Delta's Avatar
Delta
I definitely have no class!
Old May 16, 2004 | 09:11 PM
rusty70f100's Avatar
rusty70f100
Yeah, with Mystik JT-8, I guess I'm in the negative "class" area.
Old May 29, 2004 | 10:17 AM
stevieweevie
Hey johnsdiesel...i'm running the Rotella T Synthetic 5W-40...at $12.83 a gallon at Walmart i couldn't resist going to the head of the class.
Old May 29, 2004 | 02:03 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
LOL, you guys are all a class act!
Old Jun 4, 2004 | 01:27 AM
Ed's Avatar
Ed
Blue Oval, I like it! While it's not a full synthetic, it boosts the overall performance of the dino oil. I do the same, only with Mobil products, 10w30 and 10w30 Mobil 1. All of my yard equipment run on Mobil 1 oil, never any problems. Here's another real life story you'll never see in a Mobil 1 commercial. In our family room, with a cathedrel ceiling (approx. 18' high) we have a casablanca type fan hanging down from the ceiling, about ten years old. It works fine, but last month developed a high pitched and annoying squeeking sound. One Saturday afternoon, I climbed up on a ladder, spun the blades and gave it a shot of wd-40. Turned it on, quiet. About an hour of it running, it began to squeek again. I figured a bearing, or something inside must be going bad, time for a new ceiling fan. A week went by, not using the fan. Climbed up again on a whim, and shot it with some PB Blaster. Same thing, quiet for about an hour, only this time the wife nagged and complained the next 6 days because of the lingering "aroma" from the PB Blaster. Then last Sunday, as it was getting warmer outside, we really needed the fan on. Poured some Mobil 1 in a small oiler, and climbed back up on the ladder. Put about 3-4 drops of Mobil 1 down the shaft area, and a drop or two on the back. Turned on fan. Not only did it spin noticeably at a faster clip, it was mute quiet! I thought, okay, after an hour it will be sqeeking again. At least the wife was happy, and we were enjoying the cool breeze of the ceiling fan once again. Watched the entire CoCa Cola 600 Nascar race. Fan quiet! Fan ran non-stop until midnight. Quiet. Everyday this week, in use from 4pm to around 11pm. Fan is quiet and turning perfectly thanks to some golden drops of Mobil 1. What can I say? I'm very happy, saved some $ and the time to rewire and replace the ceiling fan I was expecting to do after the PB Blaster experiment failed.
Old Jun 4, 2004 | 07:59 AM
rusty70f100
That's the problem with WD-40 and equivalents, they evaporate.
FWIW, I think any motor oil would have done the same thing. I always use 30 weight for around the house lube. Door hinges, garage doors, I even use it for gun oil. I even use it to quiet down computer fans when they start making noise. Take 'em apart and put a little on the bearing / bushing. Works great and is cheap.
rsylvstr
Modular V8 (4.6L, 5.4L)
Nov 15, 2015 10:07 AM
bambishooten
Oil & Lubrication
Feb 28, 2005 11:08 PM
ericsmith32
Oil & Lubrication
Feb 19, 2005 11:58 AM
gtm245
Oil & Lubrication
24
Feb 1, 2004 10:03 PM
JoggingGuy
Oil & Lubrication
Jun 27, 2003 12:58 PM
