General Automotive Discussion
difference between big block and small block
Old May 16, 2004 | 08:06 PM
Andysutt's Avatar
Andysutt
Originally Posted by stevef100s
Not true. Ford Y block engines have center bolt valve covers. Don't EVEN ask me if they're small block or big block. LOL
I forgot, my mistake, I should know that.
And they are a heavy block
Old May 16, 2004 | 09:04 PM
ga302p's Avatar
ga302p
In general, when dealing with the older v8 engines, just look at the engines and the diference is obvious. Big blocks had big, beefy blocks. They had wide heads, and they were relatively heavy. The small blocks were lighter weight, narrow heads, much smaller looking engine. This is just a generalization, I know there are exceptions to it. One of the best examples of this is the 366? chevy Big block and the 400 chevy small block. The 366? is much bigger than the 400 externally. I believe 366 is correct, I am not a Chevy fan. I work on them when I have to.
Old May 16, 2004 | 09:40 PM
Andysutt's Avatar
Andysutt
Or the 332/352/360/390 FE's..... small cubic inch than a 400/351M but are bigger blocked
Old May 16, 2004 | 10:22 PM
jessfactor's Avatar
jessfactor
oh man....i've unleashed a monster.
Old May 17, 2004 | 09:18 AM
ggarrahan's Avatar
ggarrahan
82F100SWB-The 410 is one of the MEL engines, it was used in the Citation and Corsair, right? In 1958.
Old May 17, 2004 | 09:30 AM
Smaug's Avatar
Smaug
You're thinking of the 396. Yeah, I know more about Chevys than I do Fords, but thats because my Ford has never broke down.
Old May 17, 2004 | 09:37 AM
TigerDan's Avatar
TigerDan
According to my books, I have the 410 showing up in '66 and '67 only as a Mercury engine, but another book that shows the engine families has the MEL family as consisting of the 383, 430, and 462. The 410, as you probably already know, is an FE engine which replaced the Y-block in 1958 with the introdution of the 332-352.
Old May 17, 2004 | 02:50 PM
fordeverpower's Avatar
fordeverpower
It could be either one but chevy did have a 366 big block. i think he meant 366.
Old May 17, 2004 | 05:53 PM
ga302p's Avatar
ga302p
Thanks, I did mean 366. 366 is a heavy truck engine. C65 etc. Its pretty much a piece of junk.
Old May 18, 2004 | 06:49 AM
76supercab2's Avatar
76supercab2
Difference between big and small block
NOTHING!!!! One is a chevy and the other one is a chevy!!!!!
Old May 18, 2004 | 10:17 AM
someday's Avatar
someday
could someone tell me what a chevy 396 and a 427 are considered in terms of sb and bb?
Old May 18, 2004 | 11:04 AM
Andysutt's Avatar
Andysutt
both are big block
Old May 18, 2004 | 03:15 PM
  #28
ggarrahan's Avatar
ggarrahan
Tigerdan- Check those books again, the 410 was part of the 383, 410, 430 and 462 family of engines. In the Edsel, it was called the E-475 (475 for the torque rating), and had 345 HP. It was only offered in 1958 in the Corsair and Citation, the top line models. It is not an FE.
Old May 18, 2004 | 05:53 PM
  #29
Andysutt's Avatar
Andysutt
I was told the 410 cam in mercury cars... But never in the fords
3 different type motors w/ the same Cubic inch size maybe?
Old May 18, 2004 | 06:00 PM
  #30
nogo73's Avatar
nogo73
Its like comparing apples to oranges . Chevy also have some werid motors that don't fall in any where(409-348) that are refered to as early big blocks but they were put out in the 50's. They have come out with new motors Lt1,Ls1,Ls6, 4.8,5.3,8.1 that are just that and should not be considered small or big blocks. same deal with ford I mean when a 4.6 weights more than a 460 is it a small block or a big block It simply does not apply.I mean where does the flat head come in. Ford engines are better than chevy any way so why compare the two. If you ever get to listen to the old motors you could tell if it was a chevy, Ford or dodge. Speaking of dodge they really dont have a small block or big block line ethier.
