how to change oil in 5spd. on my 98 F-150 4.6L
I'm not sure you have the same transmission, but on my ZF5 there are 2 plugs, a drain and a fill. I ingored the refill capacity because it is supposed to be filled up to the bottom of the fill opening. Yes, you should use ATF. I used Motorcraft Mercon ATF in mine, which is what Ford recommended.
You should have a fill plug on the drivers side, 22 or 24mm wrench. Then a drain plug the lower one on the driver side also. Make sure to remove fill plug first. I think it holds 3-5 qts, can't remeber man. It takes regular dexIII/mercon tarnny fluid. just fill it till it starts to trickle out, then stop. hope I helped. There should be a quanity chart in the back of your manual( 2pts=1qt).
Originally Posted by Mike W
My 01 Ranger takes 2.8 quarts of Mercon. Get a pump to put it in with.
Welcome to FTE! I posted a quick and easy method to change the fluid in the M5OD. To see it, click on this: https://www.ford-trucks.com/forums/s...hreadid=204530
Hope that helps.
And OBTW, I have always used ATF just as the manual calls for.
Hope that helps.
