newbee questions about 4x4
Old 05-15-2004, 06:33 AM
tfowler306's Avatar
tfowler306
tfowler306 is offline
Question newbee questions about 4x4
Hi all this is my very first post on this site I have a couple of questions, hoppfuly thay will be very simple for you more experienced folkes.
(I now own my very first 4x4 1990 F150 5.8)
Note: I am not new to cars I do very well with my 88 5.0
1. Do you have to fill the transfer case seperatly from the transmission, what
kind of tranny fluid do I use in it (automatic w/OD)?
I want to do a tranny service my truck has 118K miles on it.
2. Is it normal for the truck to have some vibration while running above 50
MPH? ( auto Hubs)
3. Are there any spical service steps for the 4x4 tranny other than a fluid and
filter change?
I guess that is enough to get me started. I have already taken care of several problems with the truck since I bought it, ie. Timing was set to 5 degrees, now at 12. It also had idl problems, so I cleaned the IAC, replaced the EGR to manifold tube (two holes in it), checked and replaced MAP, Intake air charge temp sensor, and the O2 sensor. It still has a small hessitation off idle when it is cold, so I am going to try a few more things and see if I can get rid of that as well.
thanks in advance
Old 05-15-2004, 08:32 AM
Egor's Avatar
Egor
Egor is offline
Yes, the transfer case is seperate from the tranny. I'm pretty sure they both use the same fluid. Mercon. Don't think your vibration is normal, I have the same setup in an F250 and mine is smooth going down the highway, but I do have manual hubs. Go buy yourself a code reader and a Haynes manual instead of replacing parts, It will save you a lot of money.
Old 05-15-2004, 09:52 AM
tfowler306's Avatar
tfowler306
I have a code reader and so far the parts I have replaced are because I had error codes for thos parts. I had a code for MAP sensor voltage out of spec, and coolant temp low when the truck was at normal operating temp, and others...
can a bad transmission mount cause the truck to vibrate running down the road?
Old 05-15-2004, 12:47 PM
tfowler306's Avatar
tfowler306
To The Top TTT
Old 05-15-2004, 02:19 PM
FordPerf300's Avatar
FordPerf300
FordPerf300 is offline
Vibrations could be many things or a compliation of things. rule out tires by getting the tires balanced/rotated and get an alignment. Also check u-joints for play, hold the yoke in one hand the turn the drveshaft with the other hand, if there is slop, time for u-joints.
Old 05-15-2004, 10:58 PM
ATC_250SX's Avatar
ATC_250SX
ATC_250SX is offline
when you do your tranny service, make sure and see if you can drain the Tourque converter, mine had a 1/4 inch plug in it, you furn it over with a pry bar after removeing the two screws that hold on the dust cover, and there is a small plug in there, thats where the majority of my nasty fluid was.
Old 05-16-2004, 07:33 PM
Fully_Loaded's Avatar
Fully_Loaded
Fully_Loaded is offline
Where did you get the egr to intake tube from? I am looking for one for my 91 and cannot find one anywhere.
MPH? ( auto Hubs)
filter change?
thanks in advance
Old 05-17-2004, 05:05 AM
tfowler306's Avatar
tfowler306
Fully Loaded I jus went to my local ford dealer and asked for it. They had it in stock and they carged me $54.00 (I cant remember what the change was).
Old 05-17-2004, 06:10 PM
Fully_Loaded
54 bucks for that tube?????? OUCH
Old 05-18-2004, 04:57 AM
tfowler306's Avatar
tfowler306
when its broken you have to replace it. I actually had my brother try and weld it up, he is great with a welder, but ther just wasent enough metal to work with.
Old 05-18-2004, 03:11 PM
bigwhtbco's Avatar
bigwhtbco
bigwhtbco is offline
i used heater hose and it held up for 8000 miles, and its still there i just changed motors.
