BOOSTGAUGE INSTALL QUESTION
Old Jan 28, 2002 | 08:45 AM
JoeBoost's Avatar
JoeBoost
Hello ,
This past weekend i installed an Autometer Boost and Volt gauge on my 2002 Excursion PSD. I tapped the Blowoff valve to get the gauge the reading to see how much boost i am running.I wasnt sure if this was the best place to get a reading..The gauge shows i max out around 5psi.My two questions are :
1)Is this gauge installed right , or should i get a reading from somewhere else in the motor ?
2)What is stock boost of the 7.3L Powerstroke...
Thanks for any help ...
Old Jan 28, 2002 | 09:30 AM
powerstroker250's Avatar
powerstroker250
You need to tap the rubber hose coming off the "Y" manifold going to the heads. That's where mine is. I get 18psi of boost at W.O.T. with my stock truck.
Les
Old Jan 29, 2002 | 08:00 AM
JoeBoost's Avatar
JoeBoost
Is 18psi stock boost ???
That sounds kinda high to me , but i coul be wrong.
If you could-send me a pic of the place i need to
connect the fitting for the boostgauge , becasue i have no idea where
you are talking about.
You can email it to my work address :
Joe_Caccavella@DSTOUTPUT.COM
Thanks ,
Old Jan 29, 2002 | 10:39 AM
powerstroker250
Check your email.
Les
Old Feb 7, 2002 | 06:11 PM
Cheeshead's Avatar
Cheeshead
I might be able to help on you boost question. International says that the MIN. BOOST should be no less than 17psi on a stock truck. I have instaled a Superchip on my PSD and have recorded as high as 27psi. I recieved a full instruction sheet with my auto meter gauges and everything worked out fine on install. A great source of info for all you PSD fans is Power Stroke Registry, they always have great tips, along with owners stories.
Good Luck
Rosco
99 F-250 X-cab PSD 35" tires,lift,superchip,shift kit and more
Old Feb 8, 2002 | 04:23 PM
Gord's Avatar
Gord
