Newbie on gauges
Old Feb 8, 2002 | 08:22 PM
surffisher's Avatar
surffisher
Newbie on gauges
Getting ready to install some gauges. Been reading much about Pre Vs Post turbo for the pyro. Have decided to install the pyro pre-turbo thanks in large part to Alanscott's advice. But if I do that, I doubt I'll ever see a temp lower than the 300 which is the desired cool down/shut down temp. Should I install a Turbo Temp Monitor so I don't have to worry about the shut down temp? Or, just put in a 4th gauge (post turbo also)? Am I anywhere near sounding like I know what I'm talking about?? Advise please!!
01 F-350*SC*XLT*PSD*Dually*4X4*Auto*3.73 Gears Non-LS
Old Feb 9, 2002 | 12:16 PM
powerstroker250's Avatar
powerstroker250
Newbie on gauges
Pre turbo you will see less than 300*. My pyro is pre turbo and if you let it idle long enough it will get to 200* and sit on the peg. You can get a TTM if you like but if you have a minute of time in your day after your drive, you won't need it with gauges. Just my opinion.
Les
Old Feb 10, 2002 | 12:17 AM
f3504x4rc1's Avatar
f3504x4rc1
Newbie on gauges
[updated:LAST EDITED ON 10-Feb-02 AT 01:19 AM (EST)]I have a post turbo pyro. I see temps at idle 200 and running down the hwy at 450 to 600 deg. if I'm towing it's the same, but if push it jump to 750 to 900 deg so a chvey or ram will not kept up
Roman
99 F350 XLT 4X4 Dually Crwecab 4:10 Banks Stringer-Plus
Old Feb 13, 2002 | 01:45 PM
sgiraud's Avatar
sgiraud
Newbie on gauges
I don't have any gauges, so tell me something: After you are on the highway pulling a load and the temp has been 450 or so, how long does it take to go back down below 300 when you stop, like at a rest area? Does it go right down as you slow up, or does it have to idle for a few minutes?
Old Feb 13, 2002 | 04:05 PM
Jim F350's Avatar
Jim F350
Post Newbie on gauges
Where did you get the Exhaust Gas Temperature system for the PSD?
Jim
2002 F-350 Lariat 4X4 Crew PSD 3.73
Old Feb 13, 2002 | 10:43 PM
f3504x4rc1's Avatar
f3504x4rc1
Newbie on gauges
The Exhaust Gas Temperature came down as I got off the throttle and
I got the gauges from Banks with the stinger-plus system
99 XLT F350 Dually Crewcab 4X4 4:10
Roman
Old Feb 14, 2002 | 09:07 AM
Jim F350's Avatar
Jim F350
Do you mean www.bankspower.com ?
Jim
Old Feb 14, 2002 | 10:05 PM
surffisher's Avatar
surffisher
Newbie on gauges
Thanks PS250 for the input.I ordered three gauges on Tuesday from DIS. Got Isspro Enhanced Visibility Boost, Tranny and Pyro. with the pre turbo clamp on thromocople. Also settled on the tripple Pillar mount. Hope it does not block visibility to much.
I read all I could fine on where to drill the hole at pre turbo, and thanks to your Pics, I see exactly where to drill. Other than greese, any suggestions on how to keep the metal chips from falling into the turbo intake? e.g. magnet or vacuum etc.
I dropped the Turbo Temp Monitor also on your advise. No sense in the redundency.
Well, as a shade tree, I'm reluctent to start drilling holes all over my still new PSD, but theres no time like the present.
If I need help, I know where I get get it. Thanks!
Old Feb 14, 2002 | 10:25 PM
Monsta's Avatar
Monsta
Sit. Stay.
Newbie on gauges
