Stanadyne
Old May 14, 2004 | 12:08 PM
SBV45's Avatar
SBV45
Originally Posted by Tim Lamkin
Love the stuff…somewhere …here. Is my recipe for Stanadyne Barbeques sauce,...um..um good.
I think I will add Stanadyne to my line of "manly" scents of diesel fuel, Hoppe's #9, WD-40 to be used as cologne.
Old May 14, 2004 | 01:20 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Hoppe's #9.........now there is a smell that brings back memories
Old May 14, 2004 | 04:21 PM
04F250KR's Avatar
04F250KR
Thumbs up
Great stuff. I use brake free now for my Glock and Sig. But Hoppe's smells great.
Old May 14, 2004 | 05:48 PM
Mscales's Avatar
Mscales
Anybody try Howes Lubricator? I friend of mine that drives trucks said the Howes was a better choice. I even found it at the local truck stop.
Mike
Old May 14, 2004 | 06:14 PM
johnsdiesel's Avatar
johnsdiesel
Mike
I personally think the Stanadyne is the best on the market. FYI, the Stanadyne Performance Formula is actually the only fuel additive that Ford officially endorses (they recommend adding it in cold weather to prevent gelling).
Old May 14, 2004 | 09:02 PM
wilba504's Avatar
wilba504
While my truck was in for its rear main seal I had them check my water in fuel light, they did a tsb#04-09002 "requires replacement of fuel manifold assembly, performed tsb r&r frame mounted fuel module assembly cleaned out debris and replaced manifold added fuel lubricity and conditoner dditives, recheck light off no codes"
They used 2 different additives in the fuel and one was
Howes diesel treatment (qt)
the other just has a part number, PM*15* additive-fuel (diesel)
Not sure if the other one was stanadyne or not, But the dealer is using howes for some reason, so I guess it cant hurt to use it. John
Old May 14, 2004 | 11:23 PM
johnsdiesel
I wasn't implying that it was bad, just thought some of you guys might find it interesting. Howe's is certainly a recognized name.
Old May 15, 2004 | 12:18 AM
SBV45's Avatar
SBV45
Ford Broadcast messages:
Lacks or Loses Power in Cold Temperatures:
This may be due to fuel gelling or moisture freezing and reducing fuel flow. It is recommended to use a fuel conditioner, such as Stanadyne Performance Formula, to prevent this condition. Do not use conditioners that contain alcohol. Broadcast Message 0436.
Cold Temperature Lack of Power, Poor Economy, Hard Start, Excessive White Smoke:
This could be due to gelling of the fuel, formation of ice in the fuel tanks or lines or poor fuel quality. If diagnosis finds no cause for the above symptoms, try using a fuel conditioner, such as Stanadyne Performance Formula or equivalent, that will improve the cetane level of the fuel. Do not use any product containing alcohol. If the conditions improve with the additive, then find another fuel source or continue to treat the fuel. Broadcast Message 1309, SSM #17406.
Randy777
Nov 23, 2009 04:41 PM
Sabow
Mar 20, 2007 01:16 PM
Locopower
25
Mar 19, 2007 12:13 PM
dunbar15
13
Aug 1, 2005 09:53 PM
JeffreyK
Jan 25, 2005 11:28 AM
