Cam RPM sensor
Old Feb 17, 2002 | 03:23 AM
ddestruel's Avatar
ddestruel
Cam RPM sensor
Well here is an odd question I would like to use a factory ford Diesel RPM sensor which sits over the cam gear on the 7.3 PSD and are wondering what it registers off of. better yet if it were installed on a 6.9 or a 5.9 cummins anything without a cam sensor and then installed into a later truck how many magnetic marks would need to be put on the crank or what ever to get a somewhat accurate reading. To restate i want to use the facotory sending unit but i do not know what it captures as a countible signal or rotational item on the crank and can it be simulated ie. on an outside item like the crank using magnetic paint stripes? I know The Diesel Dude is very fluent in this, so if you have time Joe i would deffinately appreciate your input.
BTW Joe i did do that Diesel 6 cyl conversion it was quite fun my next will be puting another binder motor into a ford, much easier on the brain for motor mounting, unless i get ugly ideas and put a 466 into something. Thanks for the input back then.
Thanks for the help if anyone can
Dusty
Why Buy new when you can build and tailor it cheaper?
F-350 4x4 ext cab Short Bed Green Monster, it is now Sporting a 300HP 715lb/ft Dyno rated 5.9L 12v Cummins diesel w/ NV4500 5spd and custom NP205 ford T-case w/ rear spicer 1410 yoke, Converted to Sterling 10.5 gears w/3.55 gears using the 41 spline pinion and 1410 U-Joints, Power-Lok equipt Dana 60 front, 33's on 16x8" Outlaw II's. (Used to have)205000 miles, Mass air 460 w/ performance heads and a E40d to 5spd conversion and Doug Thorleys. Old EFI 460 @10 MPG to the 12 V @ 23.2 MPG @ 75 MPH and loving it.
My other toy is a '69 CJ-5 354 Hemi 4 spd 4.88's 32x12.50 MThompsons w/ power-lok 44 rear.
Old Feb 17, 2002 | 10:10 AM
powerstroker250's Avatar
powerstroker250
Cam RPM sensor
The CPS gets its signal from the holes or slots in the cam gear.
Les
Old Feb 17, 2002 | 10:59 AM
ddestruel's Avatar
ddestruel
Cam RPM sensor
Thanks Les, Thats what i needed to know.
you wouldnt by any chance know how many would you?
Dusty
Old Feb 17, 2002 | 02:15 PM
powerstroker250
Cam RPM sensor
Go to www.freeautoadvice.com/powerstroke/ On the left side of the page click on PSD pictures. Near the bottom of the page there is a pic of the cam gear, you can count the windows in it.
Les
Old Feb 18, 2002 | 02:21 AM
The Diesel Dude's Avatar
The Diesel Dude
Cam RPM sensor
If I don't forget it, I'll count them tonight at work. There is one wide window and one narrow window to let the computer know whether it is at TDC of the compression stroke or exhaust stroke. The other windows are all the same size.
Old Feb 20, 2002 | 02:35 AM
The Diesel Dude
Cam RPM sensor
There are 24 "windows" in the cam wheel which includes one wide window and one narrow window, 180 degrees apart, to let the computer know whether the firing cylinder is on its compression or exhaust stroke.
Old Feb 20, 2002 | 09:36 AM
ddestruel's Avatar
ddestruel
Cam RPM sensor
Thanks Joe and Les
You guys have been a great help, now i just have to find some type of fan or wheel to mount on a pully and get 48 clicks to one rotation of the crank.
Thanks again guys
Dusty
Old Feb 20, 2002 | 10:00 AM
harryball's Avatar
harryball
Cam RPM sensor
jl429
General Diesel Discussion
Sep 19, 2013 05:13 PM
Moulder
Sep 8, 2003 01:22 AM
ddestruel
Nov 5, 2002 10:19 PM
ddestruel
Jun 29, 2002 09:03 PM
ddestruel
Apr 29, 2002 01:03 PM
