Voltage Drop ??
HELP !! Help !! Help !!
What is going on ???
Ed
I've seen this kind of problem before and it ended up the voltage gauge itself in the dash. Either have something to do with resistor or wires.
You can check it for yourself manually by using any cheap digital volt meter and get some long wire extensions. Just connect it to the positive and negative terminal on the battery and put the digital volt meter inside the vehicle and test it with AC on, lights on, radio on, etc and come to a stop sign. Check the dash gauge and compare it to your digital volt meter to see if it shows the same voltage reading.
If both the dash voltage gauge and the digital volt meter shows 12 volts at the stop sign then there is problem in the wiring from the alternator to the battery or the serpentine bent needs replacement and make sure that the serpentine belt tensioner itself is good.
If the dash voltage gauge shows 12 volts but the digital volt meter shows 14 volts then the problem is with the dash voltage gauge.
Ed
1.) Alternators don't put out full amps until they are spinning above 1000 rpm in most cases. The higher the charging amps the lower the voltage. When the battery is charged to a float charge the alternator will alter the voltage as much as a volt and you may see a fluctuation. THIS IS NORMAL.
2.) As long as your voltage goes up to the top end of normal range (13.5 -14.9 or so) without a load on at idle or just above the system is ok.
3.) The alternator just puts back in what the system uses from the battery. The alternator doesn't run the system, although this is a popular misconception. The battery has to have enough reserve capacity to handle the load at all times. If you have a battery with too small a reserve capacity (amphours) you'll end up burning out, or shorting a cell and the battery is worthless, except as an anchor.
4.) to ensure your system is working at peak efficiency, clean all connections (body and frame grounds) that are accessible, as well as the connections at the battery, solenoid, and the starter. Get all connectors to shiny metal, and coat with di-electric grease. Use Main cables that are capable of handling the loads. Main battery cables on FORDS are notorious for being undersized and easily susceptable to internal corrosion. Get some 2ga or 0ga welding cable, have the ends swedged (inserting the end of the cable into a melted cast), and coat with di-electric grease. A little goes a long way.
Fluctuation of the gauge is NORMAL. IF it stays down at 12.5 with NO LOAD and at 2000 rpm and drops slowly......THEN you need to look at a new alternator or battery.
Larry
