Powerstroke Conversion in 78
Old Jan 25, 2002 | 08:26 PM
78SupercabPowerstroke's Avatar
I have aspirations to put a powerstroke in my 78 F250 4x4. Has anyone done it? Advise against it? Problems? If I can't do this, I'll probably end up rebuilding my 400
thanks
Steve
Old Jan 25, 2002 | 10:42 PM
theologian's Avatar
theologian
That is a very difficult mod.. you need a donor powerstroke vehicle, as you need the computer, and maybe the transmission to go with it too. The peowerstroke is lot heavier than your 400 too, so upgrading the front suspension would be a good idea. You would also need to get duplicate fuel lines, the '78 will not have them. Other than that, it should be doable, but complicated..
Wm
F450 White with Grey interior Crew Cab. Banks Turbo, Intercooler and Exhuast,
Power pack Chip, shift kit, Auxiliary transmission, electronic enhanced transmission control,
16 forward and 4 reverse ratios. 340hp 660ft lb 4 wheel drive, 4.10 gears, 12,ooo# winch
Old Feb 3, 2002 | 12:05 PM
JoeDiesel61's Avatar
JoeDiesel61
Think about how much you are going to spend to do this conversion and then figgure how much gas you can buy with the same amount of money. when you do the numbers I don't see any way this swap will save you a dime
Old Feb 6, 2002 | 10:50 PM
If I was actually planning on saving money, I'd probably jsut go buy a new truck. I'm jsut trying to satisfy a strange desire that I have right now.........
Old Feb 7, 2002 | 01:19 AM
JoeDiesel61
Ok I know what you mean. You just want to do this for the chalenge,,I can relate to that,I once did some major modifications to a mack fuel system so I could burn #4 bunker oil in it just because someone told me it couldn't be done. Cost me a bit of time and a few bucks and never really saved me anything but I made it work and I sure learned alot
Old Feb 8, 2002 | 04:25 PM
Gord's Avatar
Gord
it isn't just the challenge though...or the illusion of saving money. diesels are so much better than gas...more efficient, gobs of torque, nearly water proof with some prep, low maintenaince, high reliability....etc....i'm looking to put one in my '79...but i need to find a way to keep my 4-speed
Old Feb 11, 2002 | 07:43 PM
surely there is someone out there that has done this swap and can offer some advice. My friend just put a cummins in his 93 F250 and he found gobs of info and adaptor stuff on the net, but so far I'm comin up empty-handed.
Steve
Old Feb 22, 2002 | 08:27 PM
FTE Ken's Avatar
FTE Ken
Old Feb 22, 2002 | 09:18 PM
Scot's Avatar
Scot
Well, I put a 6.9 in a '75 F250 Highboy. Actually, it was fairly straight forward. The main difference is you will need to get a good factory wiring diagram so you can split out all of the wiring.
