General Automotive Discussion
Blinker Fluid
Old May 13, 2004 | 09:55 AM
wezol5484's Avatar
wezol5484
Next time you tune up dont forget the Hollow Spark pPug wires and the EXTRA retardent plugs.
Dont forget to periodically replace your clutch belt and your Forged Kuhneutson Valve, the number one sign of a Kuhneutson failure is reduced bored on your engine blcok.
Also remember to replace your Air Filter Bypass Kit with every Blinker Fluid change.
Other misc. things to check are
Piston Return Springs
Camshaft Rotational Dampener
Radiator Insulation Bezel
Motor Block Oil Bypass Kit
"O" Pipe (provides 100% back pressure)
Old May 13, 2004 | 12:02 PM
Quackhead94ranger's Avatar
Quackhead94ranger
DAGNAMIT, i wasresearchng all of this stuff on the net , and it's gonna take me a darn week just to find all of these things and replace them if they need to be replaced, i mean some of these things sound pretty dang expensive!! i mean the wobulator shaft, wow, thats gotta a grand or two!! GOOD GOOGLY WOO
quack
Old May 13, 2004 | 12:11 PM
bigdmizer's Avatar
bigdmizer
I was told I need to get the Gyroscopic inertia dampner located on my steering wheel fixed. Can anyone tell me how much this will cost? Is it vital? Thanks. I also noticed that my brake rotors had rust on them after my truck sat for a while, so I called the local dealership and they told me that they need to be replaced!
Old May 13, 2004 | 01:56 PM
loudfords's Avatar
loudfords
Don't forget that you need a left-handed metric adjustable wrench to get that off. And while you're at the store getting that, you also need some liquid steam, some new level bubbles, and checkered spray paint.
Old May 13, 2004 | 02:15 PM
flyboy2610's Avatar
flyboy2610
And don't forget to periodically readjust the Peterson rod, and clean the Johnson valve while you have the framistat removed (it's easier to get to that way). And most important, remember to lube the doohickey that hooks up to the whooziewhatsit.
Old May 13, 2004 | 02:43 PM
rangersvt04's Avatar
rangersvt04
man i went and checked out a set if high preformance piston return springs they wanted $110 a spring. then the 710 cap fell of so i had to buy a new one. $80 not cheap
Old May 13, 2004 | 03:11 PM
3broncocrazy's Avatar
3broncocrazy
Oh Quack, Duck tape will help prevent the blinker fluid from leaking out.......
Old May 13, 2004 | 06:05 PM
Kingsun's Avatar
Kingsun
Can anybody verify if it's true that Royal Purple is coming out w/ Blinker Fluid that is guranteed for 100k before you replace it??
Old May 13, 2004 | 06:26 PM
cjben's Avatar
cjben
how could any one forget ID-IO-T wrench?
Old May 13, 2004 | 09:38 PM
redneckmechnic's Avatar
redneckmechnic
I cant belive ya all forgot to rember about oiling the belts. theyll last 3 times as long if ya oil em up good. also dont forget when waxing to put a good layer of elbow greese on before the wax. really helps the wax to come off quicker. also when changing them muffler bearings alwasy use a good dose of alwasy seize to keep em hard to slide off. with all the cold air going thro there they can come lose real quick.
Old May 13, 2004 | 09:44 PM
Jimmy Dean's Avatar
Jimmy Dean
I think Ford forgot to putthe wobulator shaft in the 04 150s thus causing the vibration
Old May 13, 2004 | 09:58 PM
natewoz's Avatar
natewoz
Does anyone have a board stretcher in their truck? I could really use one.
Old May 13, 2004 | 10:08 PM
  #28
acarlisletx's Avatar
acarlisletx
Hehe...ever send anyone to the airport for a bucket of prop wash?
Old May 13, 2004 | 10:14 PM
  #29
75Player's Avatar
75Player
No, but while in the Navy I did send a new guy down to the bowels of the ship to get a bucket of steam....
Old May 13, 2004 | 11:00 PM
  #30
Jimmy Dean's Avatar
Jimmy Dean
We have sent peopl various places on base to get Prop Wash ( I work on C-130s) had them do all kinds of bad stuff :P
Had them looking for hte fallopian tubes in the hydraulic system before too :P
