Modular V10 (6.8l)
Oil Usage
Old May 12, 2004 | 06:38 PM
my69camaro1's Avatar
my69camaro1
Question Oil Usage
My 2000 F-250 V-10 has 55,000mi and within the past 10-15,000mi it has used around a Quart 1/2 + between oil changes. It pulls every once in a while but not often, city driving and maybe 30mi daily running 65-70mph. What's wrong with it?
Old May 12, 2004 | 09:13 PM
Munkey's Avatar
Munkey
Is that a quart and a half, or half a quart? My V-10 (45k on the miles) uses 3/4 quart every 3,000. It's common for a V-10 to use some oil, do a search for it on this forum and you'll see that many have the same useage.
Old May 13, 2004 | 09:59 AM
Big Orn's Avatar
Big Orn
Long story, short:
I decided to change from dino to synthetic about 30,000 miles ago. The initial "piston slap" noise went away immediately, but the engine began to drink the oil. (where it went I have no idea) After 4000 miles I went back to the recommended oil and since has lost no oil at all. I have gone over-mileage (about 4500 miles) sometimes and it's still on the full mark.
Did you happen to go synthetic?
Old May 13, 2004 | 04:50 PM
my69camaro1
Yep, mobil 1 syn.. 1 + 1/2 quarts sometimes more sometimes less. Just wanted to make sure it didn't need seals or something.
Old May 17, 2004 | 06:49 AM
Big Orn's Avatar
Big Orn
Did you change to synthetic 10 to 15K miles ago? That could be the problem.
I still don't know if it would hurt anything, but can't see it helping.
Old May 17, 2004 | 05:38 PM
my69camaro1
I got it with 30,000 some odd miles and it had syn. then, I have always put synthetic in. It must be nothing, just have to check it every few weeks.
Old May 17, 2004 | 06:52 PM
boxcar1974's Avatar
boxcar1974
I use synthetic and goes through 1 quart every 5K
Old May 19, 2004 | 11:46 AM
Shepard's Avatar
Shepard
Yes there are several long threads on this. The summary is that some V-10's use more oil than others. Some say no loss between changes, others have 1+ quarts. I change my oil every 3,000 miles. I check the oil between changes and sometimes have to add a quart at about 2,000 or 2,500 miles. Only place I think (some of) mine may be going is that occasional puff of blue smoke on start up. (There are several threads on that also)
bty. I use the Ford recommended oil.
Old May 19, 2004 | 01:58 PM
MYFRST10's Avatar
MYFRST10
Hey big orn, After changing back to the dino oil
Did the slap come back, or has it been fine since?
Old May 19, 2004 | 04:51 PM
Big Orn's Avatar
Big Orn
Yep, came back. But, I just ignore it. There's not enough hard evidence that there's any problems with it.
Old May 20, 2004 | 11:06 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Check out this link, and go to the NOACK VOLATILITY section. Look at the bar graph of the %'s lost through evaporation. According to this, it seems Mobil 1 will lose almost 9% of it's volume, but never says what the time interval is. This means in a 6qt V10, you'll lose 1/2 a qt just through evaporation - I'm assuming over the oil change interval, 3K maybe?
http://www.1st-in-synthetics.com/10W30test.htm
I've read just before, that 5w30 requires more high volatility molecules in the oil, so the consumption would be even higher than 10w30, which I'm assuming that bar graph shows.
Interesting reading. I wonder why I use NO oil between changes with dino Castrol 5W30 ? Nothing to evaporate? (and when I say NO, I mean "none whatsoever" - same point on the dipstick each time, after letting it sit for an hour).
I am NOT knocking synthetics, so don't flame me.
Old May 20, 2004 | 11:24 AM
krewat's Avatar
krewat
The Noack D-5800 spec is measured this way (from a tester manufacturer):
Measures the evaporation loss of lubricating oils as a sample is heated to 250°C and an air stream is passed over its surface for 1 hour.
This isn't quite what happens in an engine... I don't think our oil gets even near 250C, but it might explain the oil consumption rates some people see... they aren't burning it, the oil is just evaporating off and being sucked into the intake through the PCV system.
I don't ride my V10 hard, I hardly pull anything or carry a load. So my oil temp is probably always quite low. You other guys might be running much higher than I do, therefor more oil is "used" (really boiled off).
art k.
Old May 20, 2004 | 01:18 PM
ken04's Avatar
ken04
art k.
Wow, that was a very interesting couple of posts. Evaporation eh ? That wasn't something I'd ever heard of, seems plausible to me I guess. Don't all modern engines have basically a closed loop system in the crankcase to recover evaporated oil fumes ? Or is this a whole different animal you're talking about ? I love stuff like this so I'm looking forward to your reply, thanks, Ken
Old May 20, 2004 | 02:03 PM
krewat's Avatar
krewat
The PCV will take whatever evaporates out of the oil, suck it in the intake, and burn it - so much for emissions ... or the pride we have that we aren't oil burners!
Short-chain polymers have a lower boiling point than the rest of the oil - the same polymers that keep the viscosity low. Like the 5W in 5W30. That's quote a stretch, so they have to put more short-chain polymers in the oil, thereby increasing the evaporation rate.
Which is what Amsoil was trying to say - their 10w30 is better than 5w30 because it doesn't have the extra crap that evaporates quicker. What that does for cold-start viscosity worries me...
Now where this leaves us with the dino vs. synth oil consumption, I don't know - but I do know that many people here that say they don't burn oil use dino. While most of those complaining about oil consumption are using synth.
One of the many initial reasons to use synth was oil consumption would be lower. Guess they were wrong... at least in Ford modulars.
I'd love to see a real study of oil temp vs. oil consumption by brand and dino vs. synth.
Old May 20, 2004 | 02:45 PM
ken04's Avatar
ken04
Now ya got me curious, so would you mind elaborating on the cold start viscosity thing ? As you know, or maybe don't, I have piston slap when cold. Going to the Mobil 1 10W-30 seemed to quiet that a bit.
I'd like to see such a report also, would be very interesting. If you find one I'd love to see it, thanks again bro, Ken
