1978 - 1996 Big Bronco
Tailgate rattling
Old May 12, 2004 | 05:35 PM
nelly781's Avatar
nelly781
Tailgate rattling
my tailgate will rattle pretty bad when i go down the road. i know from over time that the swinging tire rack sags a little, so when i shut the tire, the tailgate is pulled further out. there is a lot of play in the tailgate when it's closed. what should i do?
sick of rattling,
David
Old May 12, 2004 | 06:08 PM
bronco5.8's Avatar
bronco5.8
Your striker bolt has a nylon bushing, if that bushing is worn out it will give your tailgate excessive play. If bushings are okay then try adjusting the bolt. Let us know what you've come across.
Warr
Old May 12, 2004 | 09:52 PM
nelly781's Avatar
nelly781
hmm...good point bronco5.8 if bushings are bad, do i buy new bolts and bushings come on the new bolts, or just new bushings?
Old May 13, 2004 | 09:21 AM
nickmobile67's Avatar
nickmobile67
I think the help rack at most parts stores has em. I think you can get it both ways, whatever floats your boat. Might be easier to just get the bushing, because the replacement bolt may be different.
Old May 17, 2004 | 09:13 PM
nelly781's Avatar
nelly781
hey guys, yeh, all i needed was new bushings on my bolts, and easy 4 dollar fix. thanks for yalls help.
