1978 - 1996 Big Bronco
New Starter?
Old May 18, 2004 | 09:00 PM
Cheap Monster's Avatar
Cheap Monster
Guys with the bad grounds are you saying it won't crank at all or will it grind or both? Mine will crank everytime but it will grind also. This is my 7th starter in about two months from various auto parts places. The NAPA ones have lasted the longest. The flex plate teeth look fine but I'm gonna replace it anyway. Not the funnest way to spend a week.
Old May 19, 2004 | 09:25 PM
suprajztwenty's Avatar
suprajztwenty
if its a grinding noise then its the flywheel. i took mine out last week and it doesnt look too bad but compared to the new one, its horrible. but if its no power, id say its corroded wires, or the relay. it could even be a bad alternator draining the battery, not sure. keep posting and let me know what you come up with.
Old May 20, 2004 | 03:47 PM
coolcasper's Avatar
coolcasper
I had a similar problem - it totally died one day (when I stopped for gas) and it turned out to be a totally dead battery. Replaced battery, it ran for a week, and then wouldn't start. Tried alternate batteries, connections, etc. and ended up by having to tow it to a garage. Turns out the starter was fused & had taken the relay with it. $200 later, and it ran long enough for the oil pump to die......
Old May 20, 2004 | 06:58 PM
suprajztwenty
damn that sucks. hey does anyone know if a grinding sound really is a flywheel? just so that before i put my trans in i wont kick myself later. thanks.
LloydH
Aug 8, 2015 08:19 AM
viknight
Aerostar
Jun 28, 2014 01:48 PM
ryanelwood
20
Dec 26, 2012 01:31 PM
Core250PSD
Dec 8, 2009 12:05 PM
Kijutsu
1983 - 2012 Ranger & B-Series
Sep 22, 2009 04:11 PM
