i just bought a 01 and was wondering how safe are the 100 hp settings on the 4 bank switch chips? can i just set it and run safely? also will it hurt to run a 4 inch exhaust and no muffler or cat? what about propane injection is it pretty safe? thanks, Jesse
Before running any chip/tuner, and especially propane, you should invest in a set of gauges to monitor the engine, transmission, and turbo boost. It's also a good idea to have a 4" exhaust, aftermarket downpipe, and air intake before you start modding. These will help keep the engine running in a safe temperature range. It's also a good idea to make some modifications to strengthen your transmission if you are going to run some serious HP.
alright then i take it wouldnt be very safe to put the chip in and run at 100 hp setting? what about just the 4 inch exaust and air filter upgrade? would it be safe? whats the best filter setup to use?
1)if your '01 is a diesel it should not have a cat. 2) a larger exhaust(no muffler even better) and gauges are a must( in my opinion) for a big chip 3) safe? that all depends on your right foot. i will say, i just got rid of a 3 pos. flip chip that was not working wright, it was stuck in the 100 hp setting all the time. it was very hard to keep my egt's down while towing a moderate load, to the point that i would say it was not safe. as far as propane goes, dont know, havent got there yet...
you are right there is no cat, my dads 99 has one though, i just figured mine would too. (i just picked it up a couple hours ago)
congrates i love my '01. do a search in this forum for a "crankcase vent bypass" or "crank vent Bypass" it is an easy mod and will help a little with EGT's and HP- i have a few picts of this mod in my gallery
what gauges should i get a boost gauge a egt gauge? where can i get a door pillar pod to mount them in?
whoa, whoa, whoa, slow down brother, we are old and dont type very fast ...click in the upper right hand corner of the page on "PARTS SHOP" in red letters, they got what you need
