front hubs
Old May 11, 2004 | 08:14 PM
flyguy 1999's Avatar
flyguy 1999
front hubs
i have a 1999 ranger off road that have the front hub bearings going out again abd i hate to give 300-500$for new one does any body have a bearing chang over number . i'm a machinist and have a press at work ,but i need the bearing number to cross reference it i'm trying to save money wife is out of work
Old May 11, 2004 | 09:37 PM
Rockledge's Avatar
Rockledge
I checked the Ford Manual and it only shows the hub as an assembly, it goes into zero detail about the bearing (except to say that if the bearing is shot you have to replace the whole hub assembly). No part numbers, nothing.
So you might have to take it apart and try and size the bearing yourself...
Old May 11, 2004 | 09:43 PM
ATC_250SX's Avatar
ATC_250SX
They may have a number stamped into the seal or race, any good auto parts store will be able to cross referace them, it will prbly have a manufacture name on one side and directly across, the part number, like NSK 5106 , (thats not the number just and example) and you give that to your parts rep and theyll cross refreance, or you would measure, ID, OD, THICKNES AND seals. one side both sides none? but the number is the easyest, look hard, sometimes its on the seal and sometimes on the race.
Old May 12, 2004 | 05:50 PM
flyguy 1999
thank you for looking for me looks like i might get into something scary never have been into the front end off a 4 wheel drive before does any on know any secrets that i need to know before i dive into this mess
Old May 12, 2004 | 06:00 PM
Rockledge's Avatar
Rockledge
This thread has pretty much the whole nine yards on the PVH system. On page 3 of the thread there are some links posted to pages with pictures showing the hubs partially dissasembled:
https://www.ford-trucks.com/forums/s...d.php?t=113363
Old May 12, 2004 | 06:14 PM
flyguy 1999
thank yoou kindly looks to be my weekend job this weekend
Old May 15, 2004 | 06:38 PM
flyguy 1999
did they make the fx-4 in 98 /99 trucks
Old May 15, 2004 | 09:53 PM
Ken00's Avatar
Ken00
Nope, I think they started in 2003, please correct me if I'm wrong.
Old May 15, 2004 | 10:54 PM
WXboy's Avatar
WXboy
FX4 debuted in 2002 as the top-of-the-line Ranger. In 2003 it changed and replaced the old "off-road" package. But that doesn't have anything to do with the type of hubs used in the front end if that's what you are wondering.
Old May 17, 2004 | 08:56 AM
gettler's Avatar
gettler
I have a 98 mazda and had the same problem I had to end up getting the whole assembly ($200). I did a whole bunch of checking around and found out that you couldnt just order the bering because the company that makes it (timken) doesnt just sell the bering, i think the guy at the bering shop told me that timken probably just makes that bering for ford and sells it just to ford for their front hub assemblys. I did go to the local auto parts store and they tried to cross reference the bering but the bering that it crossed over to didnt look a thing like the one I had.
ddpdep
15
Mar 25, 2020 06:41 PM
xpanmanx
Nov 10, 2014 08:37 AM
louiss4618
Feb 26, 2011 07:19 PM
rideac
Nov 12, 2006 10:02 AM
CEP
Mar 24, 2005 08:02 PM
