92 exploer a4ld transmission
Old May 11, 2004 | 03:58 PM
tds566's Avatar
tds566
how do you remove the 3 to4 shift solnoid from transmission cover is off
Old May 12, 2004 | 07:36 AM
Opera House Works's Avatar
Opera House Works
To remove the 3-4 solenoid the valve body must be dropped. I do not recommend this without a manual. If you decide to do this anyway, under no circumstance turn the valve body over. Things will fall out and you will never figure where they go. With the body dropped, the seperator plate needs to be unbolted to remove the keeper that holds the solenoid. Pull keeper with magnet. Springs will pop the plate up. You will need three new gaskets. Parts and manual are available at www.bulkpart.com
Old May 12, 2004 | 11:09 AM
tds566's Avatar
tds566
thanks for info don't think I'll be doing this
Old May 12, 2004 | 07:03 PM
Opera House Works
If you get the idea to wash it, there are two tiny plastic hocky pucks that you better find first. The check ***** are more obvious.
