Blower Motor
Old May 10, 2004 | 10:52 PM
tommyleea's Avatar
tommyleea
Question Blower Motor
I have a 77 with a 302 and air conditioning. Has anyone replaced a blower motor with this configuration? Can you access it from under the hood, or do you have to get it from inside the cab?? Thanks
Old May 10, 2004 | 11:06 PM
ford390gashog's Avatar
ford390gashog
you can get to it from under the hood it is on the firewall on the passangers side but to remove the motor you take the housing out from under the dash to get to the bolts that hold the motor check out a chilton manual thats how i did mine
Old May 10, 2004 | 11:08 PM
Mil1ion's Avatar
Mil1ion
The instructions in point form for the R & R,can be found by searching this forum.
Old May 11, 2004 | 07:09 AM
76supercab2's Avatar
76supercab2
And no the factory preferred method is not under the hood. You go in from under the dash and you don't have to drain/vent the AC.
