Passenger Door Window
Old May 10, 2004 | 10:38 PM
gi_tanker's Avatar
gi_tanker
Arrow Passenger Door Window
This has happened intermittently to the passenger side rear door where the window will roll down and not come back up. After a half day or so it would start working. Well this time it went down Sunday and will not come back up. I've check out all the fuse's and relays and all is working fine. I check the master control unit and I'm getting power to it and from it. I took the door panel off and found that I'm getting power down to the motor but its also feeding back up through the the down wire. But when pushing the down button I'm getting power to the motor and no feed back through any of the wires. Also when I push the down button the lights in the car get dim but not with pushing the up button.
This all points to the window motor being burned out, right?
Is there anything I may have missed?
Also, what is a cost of a window motor? and is it better to have ford change it or do it myself?
Any help would be greatly Appreciated.
GITanker
Old May 11, 2004 | 07:06 AM
gi_tanker's Avatar
gi_tanker
Forgot to add that this is a 98 EB Expedition 5.4
Old May 11, 2004 | 09:25 AM
buzzard's Avatar
buzzard
Sounds like a bad motor to me. A year or so ago, mine started "not" working intermittently, then finally bought the farm. I had it replaced under my extended warranty so I didn't pay much attention to cost, but I think it was something like $275 for parts and labor....if I didn't have the warranty, I'd have done it myself and saved a bundle.
Good Luck.
Old May 11, 2004 | 02:00 PM
PaulC's Avatar
PaulC
I assume the behavior is the same whether the button on the driver's master control or the button on the rear door is used.
Old May 11, 2004 | 07:47 PM
gi_tanker's Avatar
gi_tanker
PaulC, yes the behavior is the same no matter what button I use.
Old May 11, 2004 | 07:53 PM
gi_tanker's Avatar
gi_tanker
Buzzard, I priced the motor today and its $114.00 with trade in.
The labor is a 1 1/2 hour job Ford says which is about $140.00
Old May 14, 2004 | 10:46 PM
gi_tanker's Avatar
gi_tanker
Ok, I took my Expedition into ford today to have them put in the new window motor and after 15 minutes the mechanic say's that its not the motor but the door window switch. He says that the ground in the switch went out, so that was way it was getting feed back through the other wire.
So this just saved me $114.00 and they only charged me $38.00 for half an hour's work . The new switch will be in monday and I can install it myself.
Old May 16, 2004 | 01:55 PM
buzzard's Avatar
buzzard
Great news. Thanks for the follow up. This kind of info will benefit others with similar problems.
Old May 16, 2004 | 07:01 PM
cobrah's Avatar
cobrah
Lightbulb My Experience...
Just the other day I had the same problem with the exception of "mine" was stuck in the up position".
I'm no mechanic but the good "Lord" knows I have spend a lots on trivia miss-haps thats gonna happen to any road machine.
So... I went to the MAIN control driver's side with all the functions and buttons. If you look to the outer edge, you will see a oblong recess all the way around the buttons. This is a plastic plate and the area is "snapped in" and will pry up with no trouble at all.
You have 3" to 4" lead wires (so ya can pull up to see) with two major plug in's that also "snap" into a receptacle. Push on these to insure that they are seated. BOTH of mine snapped into position...WALLAH! No more window problems. This worked for me and I was exploring ...I also got my lights back on that would light up at knight on the "door panel".
Maybe this will save some folks from rip-off artist...that proclaim they had to replace the electrical module, and remove the door panel, other parafinaila called "Tracing" and lets not forget "labor cost @ at a min. of $20.00 an hour
cobrah
rbrad6937
Jun 3, 2018 12:06 PM
Beeler
Nov 13, 2016 01:15 PM
GITanker
Crossovers
Jan 22, 2015 12:39 PM
fosterslager
Jan 8, 2012 12:49 PM
threefiftyone
Jan 13, 2010 01:29 PM
