Sponsored by: Kumho
rear brake valve
Old May 10, 2004 | 07:59 PM
95soontobelifted's Avatar
95soontobelifted
rear brake valve
I'm puting a skyjacker rear brake extension on my truck. I looked at the back and saw that there is a manifold welded to the axle that has 4 things going into it, the obvious is the brake fluid feed line, then there are the 2 lines going to the wheel cylinders. What is the 4th bigger tube for? And do I replace the entire manifold with the new one I got from skyjacker?
Old May 10, 2004 | 11:40 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Axle vent line maybe? Follow it and see where it goes.
Old May 11, 2004 | 07:25 AM
95soontobelifted
Can do, perhaps some dig camera pictures will help.
Old May 11, 2004 | 03:52 PM
bbford97's Avatar
bbford97
the 4th on my truck is a vent. I think you should keep the vent.
Old May 11, 2004 | 06:03 PM
95soontobelifted
why would a closed system containing brake fluid need a vent? Is it some type of air purger?
Old May 11, 2004 | 07:15 PM
mhg's Avatar
mhg
air vent for the axle
Old May 11, 2004 | 07:17 PM
95soontobelifted
interesting. So the steel block mounted on the axle has gotta stay put. I'll just bypass that thing entirely and install my new manifold
