Building our own PCM and FICM (or how to get pilot injection back)
Old May 10, 2004 | 10:13 PM
canuck999's Avatar
canuck999
Originally Posted by ZBeeble
If you think about it, the FICM, at 4100 RPM is firing the injectors 16400 times per second for regular injection and 32800 times per second for pilot injection.
Sorry mate, can't quite follow your math here!
Old May 10, 2004 | 10:15 PM
ssls6's Avatar
ssls6
Now... back to the beginning. The PCM and the FICM are tightly integrated. Without more information, I can't tell you if reprogramming or replacing the FICM alone would make pilot injection work. Likely, the PCM program changed somewhat when PI was turned off in the FICM because the power parameters would change.
I would guess that Pilot Injection was turned off because the injectors could not respond fast enough when the oil was thick (mechanical limitations). Your probably right about the 1800 rpm cap being a result of PCM/FICM (electrical) limitations. Keep in mind that it is an assumption that the electrical limitation is a result of a low clockrate. The clockrate of the chips may be more than adequate for the sensor response time or position encoders. I can promise you the sensors & encoders cost a lot more than the semiconductors.
Old May 10, 2004 | 10:26 PM
ZBeeble's Avatar
ZBeeble
Well... problems with PI and oil can be dealt with. If it's temperature, then you need to deal with that sensor issue. If it's the wrong oil being used causing problems, then a sufficiently smart PCM could disable PI when romps were detected, etc.
In terms of sensor accuracy and electrical limitations, that's all up in the air ... but several knowledgable people have let on that PI is a power of logic failing. It's also true that more powerful logic can achieve sub resolution accuracy with sensors.
An interesting approach that hit me as I was typing this would be to make the FICM a variable clockrate ASIC design where the clockrate was generated by the CPS input --- such that the program (and the problem) might seem more static. Something to ponder.
Old May 10, 2004 | 10:28 PM
ZBeeble's Avatar
ZBeeble
Heh... sorry for responding twice . But... don't forget that there's no reason we couldn't choose other injectors as an "option" for our system. Really, when you have the source, you can do anything .
"Use the Source, Luke"
Old May 10, 2004 | 10:30 PM
cdtruckn's Avatar
cdtruckn
According to the shop manual that I downloaded from motorcraft.com,for my 2003 6.0. Pilot injection is controlled by the PCM. The PCM monitors the (EOT) engine oil temp. and the engine speed to enable the (PI Mode) When the (EOT) is grater than 50 C but less than 110 C
and the RPM is less than 800 PI mode is active
Old May 10, 2004 | 11:13 PM
nlhintz's Avatar
nlhintz
4000RPM = 4000 revolutions per minute = 66.667 revolutions per second = 15 msecs per revolution (not 250 usecs).
The injectors fire on 4 cylinders for every revolution; at 4100RPM (68.333 revolutions per second), that would equate to 273.333 firings per second, not 16400.
The math has some problems, the rest I cannot comment on. Interesting topic though.
Old May 11, 2004 | 08:59 AM
ZBeeble's Avatar
ZBeeble
Oi. I stand corrected. Was late last night after a long and tiring day. Sigh.
Still, someone who knows about diesel engines has to step up to this project to make it viable.
Old May 11, 2004 | 04:26 PM
Super Steve's Avatar
Super Steve
Sounds like a great idea for you computer gurus! How about making it so I can hook up a laptop like in fast and the furious.
Has anyone done anything like that yet?
I know on some of the newer fuel injected motorcycles you can reprogram with a laptop. Why not on superdutys?
Old May 11, 2004 | 05:26 PM
PSD Six-Point-Oh!'s Avatar
PSD Six-Point-Oh!
PI Flash>Predator>CD>Website>Anyone-who-wants-this-flash?-
Greetings!
I've been following this thread for a bit now.....am also concerned
with the lack of pilot injection even though my 6.0 CC just came
off the assembly line.
I suppose it gets into proprietary areas, but wouldn't it be feasible
to download someone's PI-enabled flash onto a Predator, then to
a CD and then to a website to anyone could get it and reflash
their truck with it?
Seems like it would work in principle, but maybe distributing this
would be a no-no....any ideas?
BTW, I have all ten fingers and toes crossed over this truck!
PSD 6-.-oh!
Old May 18, 2004 | 07:04 PM
cdtruckn's Avatar
cdtruckn
I'm looking into this but ford pulled a good one.
1st, before thy disabled pilot inj. the pcm was not OBD II compatible, Just WDS compatible.
That is y thy had the recall flash (03E03 or October flash) that made the PCM compatible and also disabled P/I .
So If you find a truck with P/I working the predator won't interface with it.
Old May 19, 2004 | 08:39 AM
clockgod1's Avatar
clockgod1
I have a 2004 build Excursion and the Pilot Injection works fine. I'm also running a predator with my truck with no problems with any interface.
Old May 19, 2004 | 09:57 AM
ZBeeble's Avatar
ZBeeble
How do you know this?
Old May 19, 2004 | 10:31 AM
  #28
jdadamsjr's Avatar
jdadamsjr
Curious...
If you are running the predator I thought it had to be at a certain flash level...
Choctaw Bob - does your still have pilot injection ?
Old May 19, 2004 | 02:50 PM
  #29
Daryl Hunter's Avatar
Daryl Hunter
I thought that the pilot injection was pricipally put in there to reduce noise.
Beyond a certain RPM and road speed other noise contributors begin to dominate and removal of PI is not going to be noticeable from an audible point of view.
Is there another performance reason for PI like improved mileage or power output? In otherwords, beyond making the truck quieter at idle and low speeds, why would all this effort be worthwhile?
Old May 19, 2004 | 02:54 PM
  #30
SBV45's Avatar
SBV45
I agree, I thought PI was for quiet idle. I don't think it is that loud now. I park mine in the garage.
